I just picked up our Model S at the factory today and am enjoying getting to know her. So far it seems like an incredibly well designed and solidly built vehicle with a few kinks I expect are related to ramping up production. The issues I've noticed so far:
Bluetooth audio stuttering. Playing back music from my iPad via Bluetooth results in periodic stuttering that most assuredly does not happen with other Bluetooth connections. Using the same device in our Lexus RX450h results in flawless audio playback.
Passenger-side mirror sticks. The driver-side mirror responded as expected to adjustments, but the passenger mirror would move in unexpected directions or stick when adjusted.
Charging cable locked by brief button touch. The first time I attempted to remove the charge cable I did so by briefly tapping the charge cable button. The light cycled through blue, then white, then back to green. Pressing the button again, even holding it down as is evidently the correct procedure, wouldn't return to a white state. I had to select "Stop Charging" from the main touchscreen before I could unlock and remove the charging cable.
Panoramic roof sticks when opening. Attempting to open the roof to any state (vent, comfort, or fully open) requires two attempts, the first time the roof sticks just as it's starting to open and still shows as closed. The second attempt works as expected.
Outdoor temperature reading is absurd. While charging this evening, I've seen an outdoor temperature reading of 82F while it can't be more than 60F or so.
Projected range resets to "instant." After changing to show my average projected range I find that on returning to the energy screen later the projected range always resets to instant rather than remembering my preference.
Call Tesla service indicated while adjusting height. Our driveway is steep and the Model S will bottom out unless raised. I attempted to raise the vehicle to "Very High" and lock it in Jack mode to prevent auto-leveling, but the vehicle advised me that the active air suspension needed servicing. The height did change and I was able to make it safely down the driveway and start charging for the night. Hopefully I can make it back out again!
Clearly some of these issues are fixable in software, and others will require service to look at the vehicle. If the most egregious can addressed shortly I'll patiently wait for fixes to the rest. Fingers crossed, because otherwise I've loved the experience.
