Model S/X/3 Paint Repair Kit on Tesla Store
privater
2016 Model S and 2017 Model 3 owner
Jun 22, 2016
254
744
That sucks. Did someone key you?
Well, I want to think no, since the GOUGE (yeah, thats probably appropriate) is in a spot that is not noticeable.
Mine was all the way down to the primer.
I think mine is to the primer too.
Dr ColorChip PPSW for Tesla's Pearl White
THANK YOU - will be ordering. Do you think this is sufficient to for this or do I need extra filler?
Should be enough but will probably require multiple coats. Mine is particularly tricky since it is on a convex surface. Be patient and let it dry 10-15 minutes before using the solvent to level off. If doing multiple coats I would wait at least several hours or even a day. I tried to do multiple coats within 30 minutes and the solvent in the paint affected the prior coat - effectively undoing it.
