Model X 90 vs 100 weight
Discussion in 'Model X: Ordering, Production, Delivery' started by bikeandsail, Jan 31, 2017.
  1. bikeandsail
    bikeandsail Member
    United States, NE Ohio
    Does anyone know if the 100 kw battery Model X's weight more than the 90 kw battery? If so how much?
  2. vigge50
    vigge50 Member
    Sverige
    I think Tesla said that the 100 kWh battery was just 4% heavier then the 90 kWh battery but I haven't seen any test of it.
  3. PedanticOne
    PedanticOne MyTesla Refresh Champion
    Bay Area, CA
    Well, the P100D is about 100lbs more than the 90D. I know there are other changes, but that might give you some idea?
    (and I'm not sure how different the P100D battery is from the 100D one)
  4. DIL
    DIL Member
    Danville, CA
    i'm wondering in general how battery weight affects handling. how big a weight penalty is 100 vs 60? will def effect dynamics.
  5. vandacca
    vandacca ReActive Member
    Hamilton
    You probably want to compare 100 vs 75, since the 60s are just software-limited 75s (Yes, you are carrying out some dead weight if you paid for the 60kwh pack).
    If @PedanticOne is correct with ~100lbs between 90 vs 100, then I would expect around ~250lbs between 100 vs 75.
  6. Halcyon
    Halcyon Member
    CT
    Would love to hear some theories on why the 100D is not faster than the 90D. I would think it should be .2-.3 seconds faster on 0-60.
  7. DIL
    DIL Member
    Danville, CA
    i have no evidence, but i believe it must be software limited to avoid cannibalizing P100D sales
  8. vigge50
    vigge50 Member
    Sverige
    It could be that the inverter is the limiting factor and not the battery wish had been the case before with smaller batteries.
  9. Jrogville
    Jrogville Member
    High Springs, Florida
    Why would higher battery capacity equate to higher performance? Tesla got better performance with the connections and fuses that allowed higher amperage and probably higher performance motors. If the connections and the motors are the same with the 90D and 100D, then the performance is going to be the same, the 100D will just carry you farther.
  10. Halcyon
    Halcyon Member
    CT
    I am somewhat assuming that the P100D is faster than the P90D only because of the battery. I don't think anything else changed? Seeing as P90D owners can swap out the battery to P100D and achieve the same results.
    • Disagree x 1
  11. vandacca
    Hamilton
    From my understanding, the limiting factor with the P90D was the battery. If the battery could drain faster, the motor could handle more power. With the P100D's bigger battery, more power was available and hence the lower 0-60 times.
  12. 3s-a-charm
    3s-a-charm Active Member
    Calgary, Canada
    The Ludicrous underline on the badging adds a lot of weight I'm told...
    • Funny x 2
  13. Snowstorm
    Snowstorm Active Member
    Ontario Canada
    Won't the 100d be slower than the 90d because it has the same power and torque but is heavier?
  14. FlatSix911
    FlatSix911 Porsche 918 Hybrid
    Silicon Valley
    • Informative x 3
  15. Snowstorm
    Ontario Canada
    Thanks, that chart is helpful. So if the 100d is 220lb heavier than 90d, then it must be slower than the 90d assuming power and torque remained the same, or does the 100d can generate just enough extra power to compensate for the extra weight?
    Tesla.com quotes both the 90d and 100d as having the same 0-60 times of 4.2s. Is that spec at curb weight or max gross weight? If it is curb weight than the 100d would have a bit of extra power. If it is gross weight then is it possible that the 100d have less payload capacity than the 90d?
  16. verygreen
    verygreen Curious member
    TN
    Unlike model S, model X has 5 seaters with relatively lightweight bench seat vs 6/7-seaters with absolutely heavy monopost seats. This should be taken into account too somehow, though I am not aware if anybody actually made the measurements to confirm the actual weight difference.
  17. vandacca
    Hamilton
    It's my understanding that the bigger battery allows for more current to be sent to the motors and I assume that extra energy can easily compensate for the added weight.
  18. vigge50
    vigge50 Member
    Sverige
    Sure, but as I understand it so is the only different between the old 85 and P85 a different inverter wish could give more current and if so maybe it's the same Between P100D and 100D. If it's the inverter and not the battery that limte the current it would mean that a bigger battery don't help.
  19. vandacca
    Hamilton
    I'm not too knowledgeable about the differences between the 85 and P85, but with the Model-X, when you get a performance vehicle, the following are done:
    - You get a larger rear motor (non-performance vehicles have 2 identical motors)
    - You get a INCONEL fuse to handle the higher temperatures/energy
    The inverter might be rated for higher current/voltage, but without a bigger battery to provide those higher currents/voltages, it would be a pointless upgrade.
    Therefore, I suspect that you need both a bigger battery and a higher-rated inverter to achieve more torque. Of course, a bigger motor is required too, but that should be more obvious.
  20. Snowstorm
    Ontario Canada
    Maybe the inverter on the 90d isn't maxed out yet so they can tease out say 5% more output in the 100d to compensate for the extra weight. The motor should not be the limit at this point and the battery can probably squeeze out 5% more current.
