Do you understand how EVs are tested? On a dyno in a warehouse. No wind, steady room temperature, steady low to med mph. That is how they get those figures. Then they use a multiplier to get what they consider real world epa range. Tesla is able to use a different multiplier because of how many different ways they test (or how little, goes both ways) so that is why their numbers seem more optimistic than most. Other manufacturers could do the same testing as Tesla and would get similarly optimistic numbers but they choose not to, to almost underestimate range in some cases (porsche).Was referring to the mileage from the filing that possibly indicates that we might get a higher mileage MY soon if there is weight savings.
I don't know about the other guy, but I didn't know this. It's a pretty stupid method imo since it completely discounts aerodynamics, which are huge when it comes to real world EV range. It also now makes more sense as to why the larger wheels make such a big difference. I'd expect some difference, but not that... which is explained when you look at the testing and what the determining factors are.Do you understand how EVs are tested? On a dyno in a warehouse. No wind, steady room temperature, steady low to med mph. That is how they get those figures. Then they use a multiplier to get what they consider real world epa range. Tesla is able to use a different multiplier because of how many different ways they test (or how little, goes both ways) so that is why their numbers seem more optimistic than most. Other manufacturers could do the same testing as Tesla and would get similarly optimistic numbers but they choose not to, to almost underestimate range in some cases (porsche).
Indeed, that's silly. The fact that they can't bother to have it done at a test track astounds me. With all that's riding on those ranges, you'd think they want some real world results mixed in.How Vehicles Are Tested
Fuel economy is measured under controlled conditions in a laboratory using a standardized test procedure specified by federal law. Manufacturers test their own vehicles—usually pre-production prototypes—and report the results to EPA. EPA reviews the results and confirms about 10-15 percent of...www.fueleconomy.gov
Detailed Test Information
EPA tests vehicles by running them through a series of driving routines, or schedules, that specify vehicle speed for each point in time during the laboratory tests.www.fueleconomy.gov
Notice unrounded ranges of 495 and 454 miles.
It is not likely they'll nerf the 4680 Y, they just won't publish numbers. Which to me looks more like the 4680 models will get the same capacity battery wise and benefit from lower weight..but nothing as far as published ranges, etc will happen until AFTER they've switched Fremont. Once that happens they'll publish new number. For most MY owners, they'll see that newer MY have slightly more range but that's nothing new. For people that actually know (or care) about the difference between the 2170/4680 models, they'll care...but a vast majority of customers won't have the slightest idea or understand it or frankly..really care...To the rest of the world it just looks like improvements on the model..lower weight, better handling, better ride, better range, etc...but in small increments..This guy goes through all the math and answers a lot of questions around potential range and performance improvements by reducing weight. In a nutshell, he theorizes that if the same kW pack size is used as in the current Y, the curb weight drops to a hair under 4000lbs.
His math says that translates into a range improvement of about 4-6%. He also calculates acceleration with that curb weight, and claims it drops 0-60 by about .5 seconds for both models. His acceleration simulator puts the 1/4 mile of the MYP in the low 11s.
Of course, the big question is how much will Tesla nerf the 4680 Y.
Those who have the 4680 batteries will notice a range increase when they look at miles remaining if they charge to 100%.It is not likely they'll nerf the 4680 Y, they just won't publish numbers. Which to me looks more like the 4680 models will get the same capacity battery wise and benefit from lower weight..but nothing as far as published ranges, etc will happen until AFTER they've switched Fremont. Once that happens they'll publish new number. For most MY owners, they'll see that newer MY have slightly more range but that's nothing new. For people that actually know (or care) about the difference between the 2170/4680 models, they'll care...but a vast majority of customers won't have the slightest idea or understand it or frankly..really care...To the rest of the world it just looks like improvements on the model..lower weight, better handling, better ride, better range, etc...but in small increments..
I feel like the extra glass more than makes up for its weight in its thermal ability to hold in heat thus saving power from the heat pump in the winter... in other words.. i would guess the double glass actually has better efficiency here in colorado in the winterHave you opened a front door of a MY without dual glazed vs one with? Feels like way more than 20# difference. In total, 20# per door is 80#. That’s almost 100#. The battery day numbers were before dual glazed front windows correct? So you have to go back to that point and add in all the weight gains to get the sum difference. It’s looking like less than 200#.
Even if that is the case, which it doesn't necessarily sound like it will be, does it really matter? The enthusiasts crowd will know, but for the vast majority, they won't care, they'll be happy about it. Eventually there will be media coverage and an article and a few more people will care but by then they'll likely have been able to shift Fremont over and it will go back to not mattering or just part of the constant innovation.Those who have the 4680 batteries will notice a range increase when they look at miles remaining if they charge to 100%.
I would go for that, especially if it came with air suspension.Model Y Plaid with 4680s?
I'd pay another $6-7k over a performance, but that's about it. For a Plaid... which had better have more than just 4680s.Model Y Plaid with 4680s?
I agree.I would go for that, especially if it came with air suspension.
I’d love air suspension and track mode.I'd pay another $6-7k over a performance, but that's about it. For a Plaid... which had better have more than just 4680s.
Yup, I'd gladly pay more for that, gladly. With my hold coming off in 3 weeks I feel like I'm going to be on the cusp of at least getting some more info on the next major update (4680?), whatever that may be. On the other hand, I feel like Tesla could leave the MYP unchanged until October and it wouldn't completely shock me.I’d love air suspension and track mode.
