  • The final cut of TMC Podcast #29 is available now with topics time-stamped. We discussed the Tesla Cybertruck's expected 1 MW Ultra-Fast Charging capability, the Tesla Semi Delivery Event, the coming Model 3 refresh (project "Highland"), and more. You can watch it now on YouTube.
Model Y Service Bulletins
You can wait as long as you want, but when it fails you will literally be out in the cold! So a little pro activity would be in order. Been there done that…
I feel that, thats why I said "glaring"... I've had warning about cameras being obscured when it was dark, it was really annoying, but I assume they'll either fix it with software or in 3 years they'll have better hardware. i'm not going to bother reporting that, but if something related to drivetrain happens, I surely would.
hacer
1,289
6,405
Clarksville, MD
I might have missed this but is there a link for checking if a VIN is in need of a 'service bulletin' or what is the process to cross-check - I didn't see anything in the app or online (unless you pay as a repair shop? Welcome | Tesla Service)
I did see Home | NHTSA for recalls but that is not the same as a service bulletin (based on my understanding)
I'm not sure if all TSB's are on NHTSA's site but some of them are. 2021 Model Y SBs. The temperature sensors for the heat-pump SB is hilariously labeled "Components: Fuel System, Gasoline"
I got MY in August 2020, when winter strolled around the heat failed and I brought it back to the SC and they replaced the PT sensors.
I recently went back about some seat issues and they performed the TSB and replaced all 3 PT sensors with the new upgraded version.
Now, my heat doesn't work again... It works in "AUTO" mode but it did fail once it got colder as well. With the fan on "MANUAL" mode it's literally just blowing cold air even after the car is warm and "AUTO" was blowing hot air.
I got the car back today and the SC said it was due to frozen front louvers, but after taking off and driving "MANUAL" mode is still blowing cold air!
Anyone else experiencing similar issues? I really don't want to go back to the SC for a 4th time in a month....
Surprised I couldn't find a separate Model Y thread for the seatbelt recall.
Folks with 2019-2021 Ys should check if theirs should be fixed.
Reactions: ffearless
MP3Mike
19,968
50,018
Oregon
So, my wife keeps finding trouble reports online. Today she found one saying that the windshield defogger stops working properly at 14 degrees F. Where can I find something that says that Tesla cares and is working on a fix? I don't see that one in the Tech bulletins.
It isn't a TSB, it is a recall and Tesla has already deployed a fix: https://static.nhtsa.gov/odi/rcl/2022/RCLRPT-22V050-2023.PDF (Though not everyone has installed it yet.)
It was fixed in firmware versions 2021.44.30.7 and newer. (Which was released on January 15th.)
Did you ever have your windshield replaced?
