Ducati 996
I had the same.Hi All.
Yesterday I completed the pre-delivery tasks for MY LR. Yet this morning I had the following text:
I've checked, there are no outstanding tasks.
Must be a glitch.
![Person shrugging :person_shrugging: 🤷](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f937.png)
Must be a glitch.
Same here. Must be a glitch.Hi All.
Must be a glitch.
There are two RHD UK Model Ys at Thorpe Park right now ready for the test drives tomorrow. I was asked not to post the photos I took (until tomorrow, obviously) but both of them were on Induction wheels with Michelin Pilot Sport EV tyres. First time for me seeing the Induction's in person and it instantly made up my mind that going for them was the correct call. Shanghai VINs. Gorgeous car. Going to make the wait until next month all that much longer
Same here, hopefully a glitch as nothing outstanding to do in my accountI had the same.![]()
Drove the grey one earlierSay hello to two of the first four RHD Model Ys in the UKView attachment 753375View attachment 753376View attachment 753377View attachment 753379View attachment 753380View attachment 753381View attachment 753382View attachment 753383
Did discuss the changes, and although they were aware, he was not sure when they will come into effect. Mentioned that Tesla have a habit of fitting and then announcing when they are about to go into customer's hands.See if you can have a poke about for any of the 2022 changes
In the Additional vechicle info look as to the processor.
also (slightly easier to tell) see if the rear window are double panels:
Did you see a parcel shelf or rear double glazing?Did discuss the changes, and although they were aware, he was not sure when they will come into effect. Mentioned that Tesla have a habit of fitting and then announcing when they are about to go into customer's hands.
I just saw the outsides so I couldn't check windows and CPU. Didn't see a parcel shelf. TBH, I wouldn't take it as a negative if the test drive models didn't have the new specs. They likely came in one one of the ships last year and may not have the stuff that's being built into the for-sale models coming to the UK next month. FWIW the VIN range was 158XXX on the test drive carsSo no test driver has checked the cpu, windows or parcel shelf? Why?
I imagine they initially won't. Given there's far more LHD countries near by, I expect they'll follow a similar trajectory as other factories where RHD came later. In the first year, the output will be very low until they fully ramp, so I expect they'll concentrate on their primary configuration until then at very least.Understandably early purchasers are keen to know about Ryzen, 12v lithium, parcel shelf and rear double glazing etc, but the more exciting proposition is cars from Berlin which will have the front of the car cast as one piece as well. I wonder if Berlin will supply any UK cars in Q2, as those Berlin cars will have front and rear castings as standard - and likely the other goodies listed above as well. All recent drone footage shows Perf and LR cars outside Giga Berlin, but no RHD yet.
Monring all,Pictures or it didn't happen![]()
No parcel shelf in either of the cars that I saw.I just saw the outsides so I couldn't check windows and CPU. Didn't see a parcel shelf. TBH, I wouldn't take it as a negative if the test drive models didn't have the new specs. They likely came in one one of the ships last year and may not have the stuff that's being built into the for-sale models coming to the UK next month. FWIW the VIN range was 158XXX on the test drive cars
Presumably Germany will get German built LR and P. Will UK get German built P also. HmmmA bit of super-sleuthing (not that it tells us that much)..
The model code for the UK LR is MTY09 and the same as the HK version, whereas the one in say Germany is MTY07
The model code for the UK Performance is MTY05 and the same as the Germany version, whereas the one in HK is MTY10
These codes usually point to a combination of battery and motors and a general sub model iteration (as you can guess, they are up to 10 iterations of the Model Y globally). You might therefore conclude that the MY LR we get will be closer to the HK version than the Eurpean one.
Also noticed that in HK you can order a Standard RWD MY but that uses a different code again..
The german cars codes have been around for a while and China built cars so not that. Our LR has been out of kilter on the M3 LR for some time as we've had the smaller battery which may be the reason, but being a higher number suggests we're now getting something newer than the Germans.Presumably Germany will get German built LR and P. Will UK get German built P also. Hmmm
