Bunes
Mine said 30 on invoice but on delivery it was actually only 7 miles.I see your mileage on invoice states 30 miles, exactly the same as mine, coincidence or just every invoice I wonder
That's correct, the off peak difference is nominal. However, I believe the peak day rate is around 0.32p kWh. The tariff they have stuck me on is 23.7p kWh and daily standing charge of 17.55pWhen I looked at this it did not make too much of a difference... 7.5p for a few hours but the daily rate increased 5P (£0.25 > £0.30Pence).
Assuming I used 200 Kw per month for the car and only in the low tariff window - which I doubt I would was £10 saving at best..
0.30 *300Kw £90
0.25 *300Kw £75
0.075 *200Kw £15 - Car
0.25 *200Kw £50 - Car
Standard difference (+) £15, (-)Car £35 = £20 - only if I charged in the 4 hrs window...
Some poor sod has to drive them all round and round the collection centre until the mileage reaches 30!I see your mileage on invoice states 30 miles, exactly the same as mine, coincidence or just every invoice I wonder
Yep same here.When I looked at this it did not make too much of a difference... 7.5p for a few hours but the daily rate increased 5P (£0.25 > £0.30Pence).
0.30 *300Kw £90
0.25 *300Kw £75
If I had these wheel I'd probably do the same.... they look good.Picked up mine from TC last friday and just got it back from the garage after having the wheels done. After mulling over the Gemini, Induction, rimetrix conundrum i stuck with the Gemini and had them powder coated in satin black. Delighted with the results for a lot less than the inductions and not that much more than the Rimetrix.
You should look around, it will go up in April and October, you could be better off jumping now rather then July - you will have to do some investigation.... Hopefully in a year things will settle down to sub 20p figures....Yep same here.
In 22 days we’ve done 666 miles and “used” 271 kWh (its 80% charged at the moment, so actually used approx 208 ish kWh).
Average driving. I guess 12,000 miles a year for us.
The dual rate makes it much cheaper to charge your car - but significantly increases the cost of our household use, which is about 4 times more than the car uses; so more expensive to have a cheap night rate in our case. And potentially more limited charging window, which we’d exceed if going on a long trip and go into the expensive zone!
Also it’s nice just being able to plug it it anytime when you get home.
We’re on SSE fixed rate of 16p a kWh till July.
After that we’ll be put on the govt. capped rate, whatever that is….? so this could all change for us !
£60 a month do do 1,000 miles.
- I’m loving the running costs so far !
Also our max range shows 326 miles.
Is this normal? Though it’d show 331. At least at first!
(The “home” and “other” below are all at home - my wife didn’t set our home as home in the car until a few days after we got the car.)
Looks great. Did you powder coat the brake calipers as well (or) were they RED from Tesla ?Picked up mine from TC last friday and just got it back from the garage after having the wheels done. After mulling over the Gemini, Induction, rimetrix conundrum i stuck with the Gemini and had them powder coated in satin black. Delighted with the results for a lot less than the inductions and not that much more than the Rimetrix.
Crikey, yes it is quite big! Actually a fair bit smaller than an X6, but it is identical size to an X4! I can't imagine that's by accident.Ye that was the first thing I noticed when driving. Not an issue, but noticeable vs the Model 3.
I also didn't realise how big it was.
Wow that's expensive, they're less than half the price on Aliexpress:
What colour, i think we might be the only two in town?We picked up our Y today at Glasgow. The advisors are super friendly and helpful. It was a great experience.
They were a couple of marks which I’ve booked in and they have a body shop on site. Otherwise the car was flawless and the build quality is as good as our 2019 VW Tiguan.
We’ve had a fantastic experience overall and it was so much better than our previous car purchases.
I heard that some people had this issue, if they were not using the official Apple cables.How many recent Y owners have working USB-C ports? all 4 of mine (2 front, 2 back) don't appear to charge my iPhone from a test last evening.
