My 1 month old model 3 loses 4-5% battery parking overnight no sentry mode cabin heat protection is off weather outside is -3 degrees is it normal or vampire drain ??
-3C? M3 RWD?My 1 month old model 3 loses 4-5% battery parking overnight no sentry mode cabin heat protection is off weather outside is -3 degrees is it normal or vampire drain ??
Normal for cold temperatures.My 1 month old model 3 loses 4-5% battery parking overnight no sentry mode cabin heat protection is off weather outside is -3 degrees is it normal or vampire drain ??
What does the Energy Screen while "Parked" show?My 1 month old model 3 loses 4-5% battery parking overnight no sentry mode cabin heat protection is off weather outside is -3 degrees is it normal or vampire drain ??
It shows Vehicle standby: 4% consumption. Interestingly the energy loss during day time when the temperature is around 5 degrees is not that much. Just 1% loss.What does the Energy Screen while "Parked" show?
I don’t have enhanced auto modeDo you have FSD? If so, make sure summon standby is off.
4% standby overnight is not unusual. What's odd is the lack of consistency.It shows Vehicle standby: 4% consumption. Interestingly the energy loss during day time when the temperature is around 5 degrees is not that much. Just 1% loss.
When the battery cools of, the screen show less SOC. Could it be that?4% standby overnight is not unusual. What's odd is the lack of consistency.
When the battery cools (parked outside in freezing conditions) of the car show less range. My car usually show about 2% less due to this. So your real loss is probably less than it looks.My 1 month old model 3 loses 4-5% battery parking overnight no sentry mode cabin heat protection is off weather outside is -3 degrees is it normal or vampire drain ??
How are you getting the HV battery/cell temps? Scan My Tesla?Cold weather is not bad for the battery itself, except maybe extremely cold weather.
When the battery cools off the screen will show less percentage. My car seem to “loose” about two percent when the battery cools to sub freezing levels.
I have the car at my work where we have about -18C / 0F.
Last charge (UMC 2kW) wednesday morning.
Right now, saturday afternoon I have 54% (About 3 1/2 days later)
I have woken the car up to check the battery temp a few times so both of the points shown above is me entering the car.
This might not be an actual loss though. I'll lose battery percent when it gets cold, but then when I kick the heat on and the battery starts to warm up, the battery percentage will grow again.
