I would not have noticed the conduit if you had not mentioned it. But, if you want to hide it more paint it black like your vent stacks.
That's a good idea.
That's a good idea.
How did the inspection go? Were you able to flip the switch?Confirmed final electrical inspection is scheduled for tomorrow morning. One step closer.
i didn't wait for the city electrical inspector... lol. i flipped the switch the moment everyone left to charge my batteries.. i come home every day from work and turn the system on for a couple of hours to test it... we failed our electrical because tesla screwed up and installed a 10kw inverter vs the 11.4kw. So the inspector threw a red flag... to be honest i would have never checked the model number... now we are fighting over it makes it difference in production. we will see what the design team says once they run the calculations again.. Took 6 days to finish the job.
i've not let it run long enough during a nice day, which there haven't been many in s. florida for the past week... The max i've seen so far at like 4pm is 7kw... again i ran calculations on pv watts originally based on an 11.4kw inverter and an 11.34kw pv system and got my production.. i guess i need to go back and do it again.. Tesla is actually re-running the numbers. if there is no difference them i'm fine, but if it's even 50watts less, then they need to make the change in my eyes.
Well I turned the system on and plugged in the gateway. Says "no signal". Perhaps because I haven't received PTO?
I believe that indicates that it can’t talk to the inverter, either because you haven’t given it enough time or because it’s too far away from the inverter. I would give it 5 or 10 minutes and then maybe try to move it closer to the inverter. I don’t believe that lack of PTO would cause a no signal light, but I also don’t believe that you will get any data in your app until after you get PTO
The Gateway is literally sitting on top of the inverter. Maybe it's too close![]()
