It's been nearly 300 posts ago in this thread... so with the most recent data and experiences I'm going to go ahead and repeat what I said earlir:
I'm beginning to suspect that there may be a subtle bug that's exposed by some combination of:
- Car H/W configuration (60 vs 85, B pack vs. D pack, etc...)
- Car firmware version
- Supercharger H/W configuration (120 vs 135KW, internal charger revision, etc...)
- Supercharger firmware version (perhaps some superchargers have recently gotten newer versions)
- Charge session conditions (outside temp, battery temp, SOC, etc...)
There are a number of permutations of the above, and depending on what the conditions when a person charges this may be a corner-case bug that's rarely manifested.
I'm with you that there has to be an explanation as to why some people get slower charging rates at some chargers. I originally just chalked it up to "superchargers are not all alike", but that's as much supposition as everything people have said in this thread.
From a trending perspective, including last night at Fremont (where I still showed a slower rate typical with charging at Fremont), I have 431 individual data points over 35 charging events at 9 superchargers. These account for ~3300 miles out of ~25k total on my car. I'm sorry if some people feel this data set is insufficient to show that I'm getting slower charging at my local chargers, but if I charged anymore I'd get accused of hogging chargers by some people. You really can't win TMC sometimes.
To your points:
-In general, the chargers closest to me (Fremont = 25 miles, Gilroy = 40) charge ~10-25% slower across the entire taper than the other chargers I've visited (Harris is the next closest at 150mi or so). The one oddball is my only visit to Buellton, which trends with Fremont and Gilroy.
- I've SCed with 6.0, 6.1, and 6.2, with various .xxx's. My data shows no discernible difference between 6.0 and 6.1, and while I only have one data point on 6.2 (at Fremont), it is trending with the previous versions. I never intended my data to 'prove' anything, so I haven't been tracking version numbers--I suppose had I done so there could be identifiable changes, but I suspect they wouldn't be more than a fraction or three of a percent either way.
-My car is a 60 with a B pack. I can't do anything about that so its really not a variable. :wink: It would be interesting if someone had the same type and volume of data that I have to see if Fremont and Gilroy are just slower for everyone. One supposition that I had when I first compiled this data is that its simply more obvious to me because I have a pretty detailed set of data and a battery that charges slower than most at the superchargers.
-I (obviously) have no idea about the charger HW/FW, but if it matters I have charged at Fremont, Hawthorne, and (I think) Gilroy pre/post expansion. And, if it means anything, Tejon [with its old school open-the-door pedestals].
-Ambient and car/pack/soak temps haven't been a huge variable. California, and all... My data goes back to ~October 2014, so figure mid-40s through mid-70s. From a trending perspective I've definitely charged at those (ahem...) 'extremes' for both of my local chargers. Night and day. Its a freeway haul for me to get to either one, and also some of my data is coming back from long road trips so there's plenty of steady-state running before charging for those events (I live at 1500ft and sometimes have to splash at Gilroy or Fremont to make sure I have enough juice to make the climb).
-Starting (and instantaneous) SOC doesn't seem to be a variable in the trending. Clearly there's more deviation at lower SOCs, but once I get to ~40% (and definitely over 50%), the max deviations in charge rate are within +/-10% of the trend. I don't consider the lower SOC deviations as an issue in and of themselves as I suspect there are plenty of variables that can affect the first 5-10 min of charging, but its fair to note that the deviations still bounce around their respective local vs flyaway charger trends.
-Charger traffic doesn't seem to be a noticeable variable. Especially with my local chargers I've been there when they're full and when they're empty. I haven't been recording traffic so I can't directly correlate, but I do mentally note the charge rate vs number of cars charging and haven't noticed anything out of the ordinary. I can charge just as slow as when its empty as when its full... If hot vs cold superchargers is a possible variable, it doesn't seem to be with me.
-Clipping due to pairing obviously doesn't factor into the "my local chargers are slower" situation. I've experienced clipping three times now (twice at Fremont, once at Harris), and its an obvious notch in the power vs SOC graph. And on a related note, despite some suggesting this is all a conspiracy theory and that people like me are posting nefarious and/or misrepresented data, fear not. I'm not that smart.
I was responding to your previous post to me claiming that throttling exists. Are you now changing your position?
Please stop pretending you lack basic reading comprehension.
