sorka
When I'm at work, I use UMC to charge the car off 120v outlet... which is enough to close the contactors (obviously) and fire up the Dc-to-Dc converter in the car.. which powers the 12v circuits keeping the load off the 12v battery as well so it doesn't cycle during the day. It also pays for my commute energy. That's another 8 hours of every day of no cycling.
I'm unclear how this helps. Even if you leave the UMC plugged in it will not draw power until the 12v battery draws down to about 50% of SOC. The 12v battery has between a 60 and 70 watt continuous load. When it draws down far enough, the contactors close and the main either the main battery charges the 12v battery or shore power charges it.
In either case, while the contactors are closed, there's a continuous load on the 12v battery drawing it down.
When the 12v battery is new enough and not degraded, this happens about 6 times a day. As it degrades, the cycles speed up because SOC draws down faster.
