I have just submitted my ticket to the Tesla battery lottery for my 2013 P85+.
3 weeks left on the 8 year warranty, the car died with multiple battery related errors.
Managed to get a TMspy reading just before it went completely black.
Do you think I have a fair chance?
If your battery died then they'll replace it if it's still under warranty. Not sure what you mean by if you have a fair chance.
What were your battery errors?
if you get to SC can you ask them what is the cause of BMS_f071 and BMS_w107 please, I have same errors but my 2013 just became out of warranty 3 months agoI meant to ask if anyone had a qualified guess if this would likely result in me getting a replacement battery and not just having the old one resurrected.
Errors:
DI_u014 Unable to drive Voltage too low
GTW_w018 Reduced power Vehicle may shut down unexpectedly
BMS_f071 Vehicle unable to start
BMS_u008 Acceleration and top speed reduced
BMS_w107 Vehicle may not restart
GTW_w370 Battery level too low
BMS_u018 Maximum battery level reduced
Plus a lot of different Service required messages
Battery was at 76% when parked, then showed 78% five hours later before shutdown.
According to ScanMyTesla it had a nominal full pack of 75,2 kWh two months ago, reduced to 71,1 kWh just before shutdown.
if you get to SC can you ask them what is the cause of BMS_f071 and BMS_w107 please, I have same errors but my 2013 just became out of warranty 3 months agoit might help me fix my car!!! thanks a lot in advance
by the wayI meant to ask if anyone had a qualified guess if this would likely result in me getting a replacement battery and not just having the old one resurrected.
Errors:
Just heard back from the SC, they have ordered a replacement battery .if you get to SC can you ask them what is the cause of BMS_f071 and BMS_w107 please, I have same errors but my 2013 just became out of warranty 3 months agoit might help me fix my car!!! thanks a lot in advance
They should update your work order when they order the part, which should give you an idea of what you are getting.Just heard back from the SC, they have ordered a replacement battery .
The person I texted with had no technical knowledge so that was all I was told.
So now the wait begins to see if I get the top prize (new 350V) or consolation price (refurbish).
Thanks keep us posted. Hoping you get the good one!Yeah, should.
No work order is visible in the app, it just says: Waiting for parts
This is the original 2013 85 kWh battery, 50k miles, spent most of its time between 30 and 80%, supercharged 870 kWh of a total of 20843 (so around 5%), 293 charge cycles. Appeared to be healthy with little range loss until failure.
Sucks really, I was hoping it would last a long time, a refurbish will likely have more wear than this.
Hopefully they will not find a refurbish that is as good, so they will have to give me a new one.![]()
They just updated the work order.Thanks keep us posted. Hoping you get the good one!
Congratulations you have won the Elon lotteryThey just updated the work order.
P/N 1014116-00-B which I believe is the new battery.
Fingers crossed...
Fingers crossed...
any solution with that pack is better than the current solution of us 85 owners.Yes, that's the 350V, ~90kWh pack. The only question is if they give you the entire capacity or cap it to what you had before. Please tell us what its range is after you have it.
I haven’t seen any instances of this battery being software locked for cars badged as 85/P85
Do have any examples of battery changes where the work order info has been different from the actual battery installed?Thanks for the link.. I would like to have seen a photo of the battery label instead of the work order.
