The older 85KWh and 90KWh based S and X were rated unrealistically high by both Tesla and EPA systems for range. Their assessment for the X was based on an assumed 90% output efficiency of the battery pack and a consumption rate of 295Wh/mile. The 90% proved to be very much spot-on, but most real-world driving conditions for the X fall around 350Wh/mile average over time. They have corrected some of this with later software updates and depending on which MCU is installed in your car (which supplier and manufacture date) it may or may not attempt to adjust rated range based on driving habits and history. And it also seems that some of the cars don’t update their rated range display at all with these software updates and still after 50K plus miles and latest software they still show unrealistic fantasy numbers. Hence people complaining that their car tells them they should be getting 235 miles or so out of a 90% charge when they really get 200 on 20” wheels or 192 on 22” wheels.
In a nutshell, once your battery is broke in properly (20K miles or so), you should see about 208 miles of range reported for a 90% charge on a P90D Model X. Give or take a few miles either way. Ours does adjust the rated display based on driving history and we dip a bit lower — I’ve seen it report as low as 204 miles on a 90% charge after several days of cold weather and running seat heaters and such. It usually settles around 208 or 210, but was reporting 216 last week after road tripping and averaging better WH/m with mostly highway driving.
Will be taking the car in for a service appointment soon, as it’s been a year. On our last appointment they ran a full battery diagnostic and they said everything was right where it should be. Car is running great, battery seems to be delivering as it should when realistic adjustments are applied to the original numbers. I have a broken pop-out cup holder that needs fixing and a rattle coming from the overhead portion of the right side FWD and a metal clip that fell out of the driver’s door that serves an unknown purpose... So just some of the many charms of this car. Which has been a great car for the 3 years we’ve had it.
