Tech_Guy
ALWAYS IN LUDICROUS MODE! P90D>P100D Upgrade
can't wait to see some numbers!! it will help me decide if its worth upgrading or not from the 1088 battery, BTW got a 2.63 0-60 time with my VBOX
Delivered already or in production?got my P100D VIN, 160XXX
Nothing worth mentioning yet need to find a better place to test...Awesome, any 1/4 mile data?
Can bus data:
Yellow: pedal
Blue: g's
Purple: distance
Black: mph
0-60 in 2.58 secs with 1 foot roll out.
45 t0 65 in 1.24 secs.
P90DL, 100% SOC, max battery ready, 19" wheels.
The spike in the black curve at the beginning is the rear wheels spinning. The speed curve then flattens out and takes a while to get back to full acceleration. This may be why the 21" wheels get better times. They are heavier and don't break loose at the beginning, so you don't get that drop off in acceleration.
Hmm. I have 21" staggered wheels on my p85+ ...
1088792-00-A@TIppy what battery revision do you have? i did not see anything from you on the p90d comparison.
Tried using TM-spy, but it drops data. I only averaged about 70 readings a second instead of the 100 per second that are reported. Wrote my own program to communicate with the elm327 via wifi, log and plot data.Which software did you log and plot with? I'll try it on mine when I take delivery.
And the cars that went to the media, of course.With the exception of the TRC car, I thought it was the cars with the 19in wheels that got th better times.
My program using wifi on a laptop works fine.Is there a wired can bus obd reader that works? Could be the same ELM 327, but with a usb to serial adapter. You might have better luck with a corded serial interface and a laptop, rather than wifi.
Oh, my mistake. I thought you were saying that your program was only giving you 70 updates per second, not the full 100 updates / second.My program using wifi on a laptop works fine.
I think TM-spy only support bluetooth and wifi.
I've got 21" staggered wheels on my p85+ that I'm going to move to the p90d.Oh, my mistake. I thought you were saying that your program was only giving you 70 updates per second, not the full 100 updates / second.
Mind sharing your program and which ELM wifi reader you are using? I'll use it to compare on my car with 21s.
Thanks!
Can bus data:
Yellow: pedal
Blue: g's
Purple: distance
Black: mph
