My understanding is that you can currently tell a Tesla when to automatically start charging but not automatically stop charging. For a ToU electricity tariff do you tell the Tesla to constantly charge but then tell the charge point to only charge during the cheap electricity period?
Some Wall Chargers can do things like "schedule stop charging" ... worth considering how you will override that (i.e. using the APP) on the days when you need longer charging.
There are various 3rd party APPs for Tesla which have schedulers - so that can be used to STOP the charge (a few minutes before end of Off Peak rate for example). You then have to decide what to do on the days when you need a full charge AND car is sufficiently depleted to need to carry on after Off peak finishes ... for me that is "forget to do anything and then Curse the following day" ! Hopefully you are more organised than me. (Let me know if you need a referral code for
TeslaFi)
I do have an "override" schedule in my 3rd party app - which resumes charging a couple of minutes after Off Peak ends, which I can enable on the few times I need it ...
I also have schedules for other things:
Pre-condition the car shortly before I leave for work (weekdays only, and only if parked at HOME GPS location)
Similarly before leaving work (again if parked at Work on weekdays)
Charge to 100% aiming to finish shortly before departure time (i.e. on a long trip) and pre-condition 15 minutes before that ... and turn everything back off if I don't actually leave!
I would still use Tesla Scheduler to START the Off Peak Charge and not rely on anything else for that - then if all else fails, e.g. the "other thing" fails to talk to the car, at least it will start charging.
Tesla Scheduler WILL start the charge if you have a really good night out
and arrive home after the normal start time ... 3rd party might not do that ("Retry for 5 minutes then give up")
Beware if arriving home "empty" and doing an "immediate" charge that you don't turn that schedule off (OR [unlike me
] remember to turn it back on ! )
It is aggravating that it is so complicated when you want to do the "out of the usual" ... so needs some lifestyle adjustment
To be fair, OP is talking about having a PodPoint installed. That costs more/less £300 (depending on tethered or not). Buying and installing a Tesla charger is likely to be around £1,000. £700 could be a lot to spend on something that is prettier, but does basically the same job.
IME OLEV grant doesn't cover the full cost of the typical charger - so you wind up paying "installation/wiring cost plus a bit". That has usually been attributed to either Greed or "Cost of doing the OLEV Red Tape"
Tesla WallCharger is £460 - so should work out about £400-£459
more expensive than an OLEV install. There may be OLEV units that avoid having to have extra earthing rods or additional safety kit, which could work out cheaper (unless the units themselves are exceed the OLEV grant by a lot, of course)
List of wall chargers:
EVSE Options - Google Sheets
