NoUserName7
Could you let me know how to set a holiday mode please? I don’t see such a function in the Tesla app or octopus app.Just set holiday mode on the app. Car sleeps as normal.
Ah, never mind. I realised that the term is “smart charging” in the Octopus app.Could you let me know how to set a holiday mode please? I don’t see such a function in the Tesla app or octopus app.
Er, if you have a Tesla the charger you have is irrelevant. You put the Zappi in dumb mode and Intellegent controls the charging via Tesla’s API.This would save me money vs Go (about £5/ month) but it doesn’t currently work with Zappi. Hope they fix that soon.
Er, and yet when I put my details of car and charger in, they reply with this:Er, if you have a Tesla the charger you have is irrelevant. You put the Zappi in dumb mode and Intellegent controls the charging via Tesla’s API.
Bet you it works if you choose a different charger (like a Rolec). Obviously if you forget to configure the Zappi correctly, weird/unexpected things could happen.Er, and yet when I put my details of car and charger in, they reply with this:
In other words, it doesn’t work with MyEnergi products yet.
If you can put the charger (any charger) into dumb mode, it will work.Er, and yet when I put my details of car and charger in, they reply with this:
Yes, but the point of the Zappi is to top up the car with free solar, so by gaining on one hand with a longer 5p rate, you lose the functionality of charging the car for free. I think MyEnergi are working on a way to get both (smart charging with Intelligent Octopus and Eco++ with PV), but they aren’t there yet.If you can put the charger (any charger) into dumb mode, it will work.
It does. Just choose generic charger.Er, and yet when I put my details of car and charger in, they reply with this:
This meant I put in my Tesla app details for (I presume) polling.
You can't tell the Zappi that the cheap rate is from 23:30 to 05:30 and let it manage everything? The *single* benefit of using the Octopus app to manage the charging is *if* you need more than 6h to get the car to the needed charge (bearing in mind 10h gets you from 0-100% in a M3LR), Octopus will give you extra cheap hours (supposedly, I have never seen this in action).Yes, but the point of the Zappi is to top up the car with free solar, so by gaining on one hand with a longer 5p rate, you lose the functionality of charging the car for free. I think MyEnergi are working on a way to get both (smart charging with Intelligent Octopus and Eco++ with PV), but they aren’t there yet.
I guess I could keep flipping between holiday mode on the Octopus app and Eco++ on the MyEnergi app, but it’s not ideal. Would rather not negate the benefits of the Zappi.
Change your Tesla account password, anything connected will then stop connecting. I don;t know this app, but it's often the case that if you have multiple apps using your password then as they don't co-ordinate between them they can keep the car awake with their polling, when one app along wouldn't.Ok decided for now to pause but went as far the point where the app asks to do a test charge but stopped before I did this. This meant I put in my Tesla app details for (I presume) polling. Now I have a situation where it seems I'm losing 3-4% battery a day but I'm not even on intelligent octopus . ... So I can't charge into holiday mode Call to octopus tomorrow sounds like.
I hope to make the switch just don't want to have the app drain the battery.
For info the car is plugged in but I've got my pod point set to charge only at octopus go times.
Everytime I've went into the garage in the last couple of days I've heard the car humming away to itself implying it's not going to sleep now.
I’m with you now; so play the application system to get onto the Intelligent tariff, then just don’t use any of the Octopus smart functions and keep using Zappi as normal, but with a longer low 5p tariff? Basically turn smart charging off in the Octopus app all the time (unless you need to charge at an unusual time?)You can't tell the Zappi that the cheap rate is from 23:30 to 05:30 and let it manage everything? The *single* benefit of using the Octopus app to manage the charging is *if* you need more than 6h to get the car to the needed charge (bearing in mind 10h gets you from 0-100% in a M3LR), Octopus will give you extra cheap hours (supposedly, I have never seen this in action).
How would that help you?Basically turn smart charging off in the Octopus app all the time (unless you need to charge at an unusual time?)
That's good to know, thanks.That's not how it works.
Based on the % charge and ready times you want Octopus do look at *all* the HH slots in that time range.
For example, if you want your car ready by 11am, there is nothing to stop Octopus shifting your charge from 7am-11am because they're the lowest charge/carbon slots for Octopus. This happened recently (note the Agile price plunge).
Crucially, you still get the 11:30-05:30 at 5p. Plus, in the example above, the 0700-1100 slots at 5p too.
I have had loads of slots from Intelligent outside of the published window.
The power drain caused by the app is pretty significant -- 3-4% per day for a M3LR (I don't have my car plugged in 24x7).How would that help you?
I think you need to go back, understand how the tariff works, then decide if you want to miss out on 5p slots outside of the fixed 6 hour window.
The tariff also has a fair use clause in the t&cs. Octopus are within their rights to move you off the tariff if they deem you haven't made use of the smart charging element. I'm not saying they would, but they could.
Do you think you've found a loophole in Octopus' logic? Could you plug the car in on any given day at 7am, and expect it to be charged by 11am at 5p per kWh? I expect the answer is no,
