How exactly was this? This is the thing we see often from people who are new to this. They drive here and there in short trips over the course of several days without charging, and then ask why the usage looks so bad. They don't seem to realize that it's not just like liquid sitting in a gas tank, which doesn't really change. The whole time the car is sitting, there is some idle use that is also sucking away some energy, and EVERYTHING comes from that same one single battery, so that's not just for your driving distances--that also has to feed the beast of idle drain, summon standby features, sentry mode (security cameras), etc. Some of those can be turned off to reduce that idle usage, but if you didn't know about that, it can surprise you.
And the other part of that is that energy usage is high during the first few minutes of a drive, as it warms things up some. So people do 5 short drives of a few miles each, with the car sitting and cooling back down for hours in between, and are wondering why it's using twice the "rated miles" as their actual distance.
If you drive in a longer continuous trip, it is much better because it counteracts both of those aspects: less idle time, and that high startup usage spread out over a much longer distance.
