Johan
Ex got M3 in the divorce, waiting for EU Model Y!
Thor, how hard is it to consistently use the correct spelling of "brakes?"
Any better?
Much better. Now let's give this whole spelling thing a brake and focus on the breaks.
Any better?
Got it. Ok to use someone else's god's name in vain.Much better. Now let's give this whole spelling thing a brake and focus on the breaks.
Ouch!
Mine is a March 2013 with 201 000 KM ... I'm worried now!!
Jez......
When it comes to brakes, different climates require different levels of love. If you live in one with high humidity and salt on the roads you need to have the brake fluid changed every year to prevent brake breakageIf not, moisture accumulates in the fluid (it is hydroscopic which is why it always sucks all the moisture out of your skin when working with it) and will draw in ambient moisture. This moisture will attack the piston/wall interface in the caliper and drive the need for replacement.
My question is why is none of this covered on the extended warranty? I have the extended warranty also and I'm about to go into extended warranty territory, so I'm curious why nothing is covered. The suspension piece, for example, is not wear and tear, that was a manufacturing decision, and I think likely one that required quite a few retrofits of a revised version of that part.
I've had all my brakes changed while on the original warranty (including rotors), is the extended warranty that different?
Bit of a warning to early model S owners and others. I have owned a model S since Dec 22, 2012 and I bought the extended care package. It has gone through 4 winters, 2 hard ones and 2 warmer ones. The car has 104,000km on the odometer.
Last year I started hearing a rattling noise in the right rear and it turned out to be a loose parking brake pad. That got fixed and this year the other side started rattling. As well the breaks seemed to be a little soft but in no way concerning. After 3 weeks waiting for the appointment I dropped the car off and got a call saying that all 4 break pistons has seized and it would cost $8500 to repair! Wow. That is the most expensive repair I have ever had on a car. By a long shot. I was told that because the breaks are not used that much the pistons can seize. So one of the benefits of regen might not be so much of a benefit at all. Apparently Tesla is recommending a break servicing for cars in the northeast every year. I was also told that there was lots of wear left on the rotors and brake pads but they wanted to change them all out as the rotors were heavily pitted. They also mentioned that I should break hard a couple of times a week but I'm not sure if that is official Tesla policy.
Here are some of the part costs costs:
Break caliper assembly with piston (each): $745.00
Rear rotor (each): $331.00
Front Rotor (each): $290.00
Parking break caliper with pads: $1,235.00
They also replaced a the upper control arm on the driver's side: $261.00
Tesla managed to salvage one of the pistons but they had to change out 3 of them agreed to not charge for labour on the job so my final bill was $5,824.75. I was not expecting that when I dropped the car off.
I asked Jay (who is as helpful as ever) what other 'surprises' I might be in for and he could not think of any but I am nervous.
So Tesla may have an issue with this or is might just be my car but I certainly recommend everyone in the east (and especially Sig owners) have their breaks looked at right away. I would have one of the earliest cars to go through 4 winters but a near $6K repair bill does not make this the cheapest car I have ever owned.
It is hard to swallow getting a complete brake replacement when the rotors or pads were not worn down.
Tesla service people were great as usual.
The other question is, can any other garage do jobs like this? Lots of Tesla don't go to service center for a set of new tire, then why breaks?
You still have your March 2013 car?? Did you sell the P90DL?
