I haven't been paying attention to what rear motor the 70 non-D has. That said...
P85D has ... (large) rear motor and inverter, the 85D has a different (smaller) one. Correct?
Agree.
However, that still validates this statement from eclipxe:
You can put the P85D in 70 mode and get better range. Even disables front motor completely
which makes sense if the P85D and 70 uses the same rear motor.
I see a few issues with that (combined) assertion:
1. The P85D will have extra weight (front motor) and thus different front/rear balance.
2. The P85D and 70 will have different frunks (space, contouring, etc.).
3. Some P85Ds have the Plus suspension. To my knowledge, no 70 does.
4. Wheel differences due to staggering or not, 21" or not, etc.
5. In the early days of Model S, the P85 was described as having different inverters and cabling. If the same applies to the P85D but not the 70, that's another pro/con (probably pro) for the P85D in the efficiency comparison.
6. Even with the front motor inactive/disabled, is there "bleed" of power "systemically" vs. the 70? I have no idea.
#1, #3, and #4 are likely significant. I suspect the rest are not.
Broad brush strokes...
My understanding and expectation is that the "performance mode" feature is designed to help people evaluated the visceral/performance difference not the economy difference of the configurations. As such, the (IMO) secondary opportunity to evaluate efficiency is interesting but not something to lean on too heavily.
