I'm curious what hardware changes they've made.
Rumor I heard months ago is that all LDU's (Large Drive Units) have the P high current silicon, but were only tested to required power level (lower on the RWD 75.) That said, the 60-75 has always had inherent power limits since its 14 module pack is only 350V while the 16 module pack of the larger packs are 400V. The reduced voltage also reduces the maximum Supercharger power level. So I wonder, did they modify the 75 battery? Is it possible that they changed the configuration to raise the voltage? And if so, will Supercharging speed up for the small packs?
Or maybe, with all the incremental weight savings over the years, the 350V pack is now enough to pull off the reduced times with the single LDU setup as well as the small motor D pair.
I'm looking forward to seeing some 75kWh battery part numbers from the new cars.
