Tha_Ape
I figured out what caused a majority of mine and I suspect other people's.
If you use cruise control, it will limit your speed to x amount over the the limit.
Sometimes on on/off ramps or crossing other roads it gets confused and uses what ever limit it thinks the off/onramp or bridge crossing the highway is.
Eventually I learned to look at the display during unintentional slow downs and saw the the perceived speed limit changed (or type of road). If you're on a back road it won't let you go more than 5mph over the limit with autosteer, but that limit isn't in effect on the highway. So when I am going 80 in a 65 with no issue and get on a 65mph offramp it would slow me to 70 unexpectedly.
Anyway, it doesn't solve the problem, but it's easy more predictable.
People that live in different areas will likely have different results. So i can totally see how some people have never had it happen while others have it happen frequently.
For what is worth, id say it happens to me once every couple of months because the roads I normally take are fine. It's generally when I'm going to a new place
