What the %$#@&^*?
Anyone try to get the app on an iPad? The description says iPad, iPhone, iPod touch, but I sure as heck can't get it on the iPad.
I bought 3 Model S's from Tesla (long story). I wonder what happens when you have 4...
Got the iPhone app running this morning, used it for a couple minutes and went about my day. I noticed my iPhone's battery was draining out much quicker than normal. I think the app might be running in the background and draining the battery, anyone else notice this? I had to manually quit the app to stop it...
I have found that the interior temp is only shown when "Climate" is "On." What you're referring to, I think, is the temperature setting.The app says the interior temp of my car is 76 degrees. It's been sitting outside in 45 degree weather for 6.5 hours with climate control off...don't think that function is working!
All you have to do is kick it into a "Range" charge, then after it has started knock it back to "Rated" and it will continue to 240 miles.Interesting experiment: I plugged into the ChargePoint charger at my office this morning, and it quickly got the charge up to 241 miles (the usual Standard charge on my car). Over the course of the day (10.5 hours), that slid to 224 miles. Preparing to head home, I just kicked on the Climate and shifted the charger over to Max Range.
Key point: the ChargePoint connection was still live and let the charging rate ramp up, even after sitting at zero for 9 hours.
I noticed (and reported) similar behavior on the Android beta app some weeks ago. But it isn't all the time. On the android device, it seems to be related to GPS, maps, or failing to allow the phone to sleep. But it's inconsistent enough to be hard to pin down. In fact it was some weeks before I concluded it was actually the app doing it.
Some screenshots of my drive home (yes tough to press the 2 buttons while driving)
Wow Mitch, you were only doing 9mph on the freeway? Surprised you didn't get run over.
Car is outside. Interior cabin says 7 degrees c. I started the cabin heat and setting was at 24 degrees c. I can increase the temperature using the up arrow but I cannot decrease it with the down arrow. Anyone else see this?
I downloaded the app this afternoon. My car is now charging and the app says it is charging at 7 mph, 244v, 16amps. It says the rated range is 183 miles. This seems strange to me as it is plugged into a NEMA 14-50, 50amp outlet. I know the charge rate slows down as it gets closer to fill charge, but 183 rated
Miles doesn't seem like it's that lose. I have the charge setting on standard, not max. Does the reported info on charging rate and amp draw seem right?
P1117 Sent from my iPhone using Tapatalk
