You can always upload to YouTube (and make the video unlisted there if you wish) then post the URL in this thread.I have a video of how to pull out the A Pillar trim but can't find a way to attach it here.
Great write-up! We did exactly this install with a Valentine1 in our Model 3 back in 2020, and it has been working out great. No issues with it powering off when the car goes to sleep, and waking back up when the car wakes up.After much reading about the difficulty of finding a switched 12v power source in the refreshed Model S Plaid, I decided to go a different route to achieve the same result.
I mounted my Escort Redline 360c with hidden wires from the cigarette lighter adapter all the way to the mirror which achieves both turning on/off with the car as well as having the mute button somewhere accessible while driving.
Hopefully this guide helps others who are interested in this solution.
Parts:
- Redline 360c radar detector, EZ Mag Mount windshield mount which comes with it and their 12-volt SmartCord which also comes in the box.
- Instructions would work for a Valentine1 or other radar detectors as well
- 2 telephone cords - MUST HAVE 4 strands in order for the mute button to work on Escort radar detectors
- I used the Valentine1 8' cord 8 ft Straight Power Cord | Valentine Radar Detector Products
- I also used the Valentine1 3.5: cord - https://store.valentine1.com/store/item.asp?i=2031
- A phone cord I already had at home didn't work, so test the connections and that power flows before going through the trouble of the install
- 2 In line couplers to connect extension power cord to SmartCord. I needed 2 because it seems one reverses the wires and the other reverses them back. Using 1 caused an error. I used Monster 140164 which were a few dollars at Ace Hardware.
- 10mm socket
- Pry tool
Wire path:
Parts:
Wiring location along windshield. Can be pushed in by hand.
The A pillar trim pulls out from the top. Be careful not to pull too far since there is a white plastic connector that has to be undone.
There is an existing track that wiring runs through which I used as well.
Once you run the wire down the A pillar, you have to remove the kick panels above the brake/accelerator. The first one pulls down since it's held on by magnets. The second has to be removed with a 10mm socket.
View attachment 735266View attachment 735267View attachment 735268
Finally fish the wire through the back of the center console with one hand inside the console and one pushing the wire through from the back. You may have to pull the center console panel to the side. Again these are attached with clips that can be pulled out.
Finally make the connections inside the center console.
Finished product!
That's useful information.
I trust the Tesla engineers didn't forget to have some means for the main batteries to maintain the 12V. Might this not be like Sentry Mode and other vampire current draws the car is designed to handle? Pennies a day with no harm to the 12V battery?
So many posts on these forums have helped me and I feel the obligation to help others that way I'm giving as much to the community as I'm taking. Very happy to hear this was helpful for you. Who knows, maybe something you post will solve a problem I have in the future.Alb, Thanks for taking the time to photograph and share this with the community. Received my Plaid in October, just got around to wiring the detector today after ordering the few parts you recommended. I went over the passenger side instead, for two reasons. Used to be a spot to the right of the mirror on previous model S that didn't have the windshield coating that blocked reception, not sure if that still applies. Also, I prefer to have full use of my sun visor. Install took less than 15 minutes with your guidance, just amazing. People like you are a joy to have in the community. My turn to give back next time. Sincerely appreciated.
I can confirm the Model 3 Blend Mount worked perfectly in my 2021 MSP. I just haven't figured out the hardwire power yet, so using the coiled cable to the AUX port, ugly but works.I think that the refresh has a revised mirror such that the Blendmount for the M3/MY work.
I have a Plaid with a Blendmount. The Model 3 version works perfectly. Haven’t got the power tap just yet, but there is nothing to concern yourself with the mount.Nice writeup and parts list. Thank you for sharing and providing insights to the pillar process especially. I will hopefully be doing the same once my MS LR arrives fairly soon! I still have Gen1 Valentine1 and previously used blendmount products in all my past vehicles. Was fairly disappointed to learn there isn't a version that seems to work well out of the box with the Tesla tapered rear mirror stalk so may explore the suction cup idea you present. From another thread here it seems people are finding the OBD2 port on the new refresh S Plaid/LR (drivers side footwell) also seems switched and would reduce the cable run and possibly the extra adapters needed to get to glovebox. If you tried that approach, what was your experience? Just for funsies I bought a couple of parts of Amazon to test along with looking up pin-outs for V1 and 4-strand RJ11 cable. I'm not sure how this would work with the remote mute functionality that I guess is baked into the cigarette adapter piece in your pics.
OBD ll Power Adapter Wiring Harness
4-pin Modular Keystone with Screw Block for RJ11 cables
