I have heard the pump noise, both when charging and when sitting idle, but it is certainly not on all of the time.
I have found that temperature is the biggest factor, and powering off the car via the screen just powers it down a few minutes faster than just parking it. Very little difference there. Temps below 45-50 F is what really suck the juice down.Silencing the Vampire - A troubling element of the vampire losses on our Model S was the electric motor soundtrack which I heard at all times, whether the car was on charge or not, and which continued even when the car was unplugged. While it was a relatively quiet motor, it was running all the time and seemed to be somewhere in the front half of the car. Picking up on a suggestion earlier in this thread, I have taken to turning the car off (on the main screen) whenever parking it, and this past weekend measured the power consumed to keep the battery topped up. During the first 24 hour period I turned off the car without getting in and was pleased to hear that the motor noise stopped. The next daily top up used 4.3 KWHrs of electricity. While this is better than the 5.3 KWHrs/day that I measured over the course of the month of February (with the version 4.2 software) it was not much better than previous tests with the version 4.3 software. More troubling was the fact that the pesky electric motor was turned on again by the charging cycle and continued running after the charging was complete. I powered off the car again and silenced the motor and left it for another day. This time the top up used 4.03 KWHrs of electricity, which is still inexcusably wasteful, but is better than I have previously seen, and the electric motor remained off after the charging was complete.
Have others noticed the electric motor noise and/or seen any benefit from manually powering down the car whe leaving it? Does it make any difference whether you sit in the seat when powering it down (I had the impression that a number of additional systems are powered up whenever you are in the driver's seat)? The car is indoors with the temperature around 9 degrees C (or around 48 degrees F). By way of reference 5.3 KWHrs/day corresponds to around 220 Watts of continuous power consumption, 4.3 KWHrs/day corresponds to around 180 Watts of continuous power consumption, and 4.03 KWHrs/day corresponds to around 168 Watts of continuous power consumption.
That is consistent with what I'm seeing (a little less when the car is in an unheated, but warmer than ambient garage). I've also never seen the range numbers "come back" and yes, they continue to deplete at a typical rate when I drive.
Could the noise be a coolant pump for the pack?
Same here.
I was wondering in cold climates in future firmware upgrades dealing with "Vampire" load there might be an advantage to having the option of limiting the amount of battery heating until such time as the car is expected to be driven. For example, on a cold Canadian evening while you are asleep does the battery pack have to be continuously heated? Say you set your timer to have the car charged by 7:00AM the software could also preheat the battery pack only before you need to drive.
My understanding is that, within reason, cooling a battery preserves the life so in addition to reducing Vampire load such a firmware upgrade might also slightly improve battery life.
Larry
Thanks Jerry. Vampire thread?
I am increasingly certain that is the case. The seems to be emanating from the front of the car. I would very much like to get a shop manual so that it would be possible to better understand what is going on under the covers.
I had a dedicated meter installed on April 4th. Yesterday, I looked at the totals. Over the 21 days, I drove 278 miles. The car says I used 92kwh, for an average of 331 wh per mile. My wall meter says I used 160kwh total. So 68 went to charge the battery (I'm guessing around 8 or so of the total), power the electronics, and manage whatever battery heating and cooling occurs (over this range of temperatures, I don't know if there should be any battery thermal management). This works out to about 3.2kwh per day, a bit lower than RichardC's but in the same ball park. So overall, more than 40% of my power consumption is unrelated to driving. Temperatures ranged from low thirties to maybe 70, with the median probably in the 40's and software is 4.3. Car was not powered off. Car was plugged in every night.
Bottom line: Tesla needs to make restoring sleep mode a high priority.
I agree. My math works out to be about 4.7 kWh per day. thats... crazy! I've taken to charging and then unplugging the car..just in protest
