I think I might have found some answers to questions about battery heating in the Model 3. Our setup: we have a Tesla wall connector installed in the garage dialled down to deliver 36amps, and an exterior 240V Flo charger for non-Tesla owning visitors set to deliver 30amps. In the first two attached images, I kept the doors open to completely cool the interior of the car down to ambient temp before I start charging at 3:36PM. We can see that the battery is cold and that there is a "Limited Charging" warning with only a 16 amp draw. The Model 3 seems to think that the charge cable might not be inserted properly, so I tried to reinsert several times without being able to remove the limited charging warning before starting. The charging light inside the charge port door is flashing yellow instead of green and I set climate control to HI using theTesla mobile APP. At this point, I am not sure that the car is actually doing anything in terms of charging or warming the battery. In the third image 6 minutes later, we see that the battery is still cold with the blue snow flake icon present, and the Model 3 still shows the same 'Limited Charging' warning with the same 16 amp draw, but now it shows +1 km in range. Images 4 and 5 approximately 11 minutes later show that the blue bar and snow flake are no longer present, and while I have the same "Limited Charging" warning, the Model 3 is now showing +5 km in range. If you look closely at image 4, you can see that the charge port is actually displayed in yellow. A short while later, I moved the Model 3 into the garage and started again. Images 6 thru 9 show the effect on charge rate by turning climate control on. With the same warning and 16amp draw, the charge rate goes from a peak of 9 km/hr at 4:23 to 0 km/hr at 4:37 with climate control on. I then turn climate control off, and at 4:43 the "Limited Charging" warning disappears, the Model 3 is now able to draw 36 amps and the charging light inside the charge port door turns to flashing green as shown in image 10. Turning climate control on was still limiting the charge rate after 32 minutes of charging even when the car was able to draw the full 36 amps being supplied.
Some thoughts: Image 11 shows the heat wave icon in the centre with the word Heating underneath, which I used in a previous post. Although I was not quick enough to capture that at the start of this trial, that image did appear for a very short period not long after turning climate control on at the start. Could this be the Model 3's missing battery warming icon? I think it might be, and instead of displaying constantly, it activates to indicate that heating the battery has started and then reverts to the defrosting screen to show interior climate control status. It is either this, or the method of using the motor to generate heat for this purpose is extremely efficient because it was on for less then 2 minutes(maybe even less then 1 minute) and never returned. And it is clear that the battery was warming as it took less then 11 minutes to clear the blue bar and snow flake icon status. Is the rewarm shown here resulting from the charge itself, or was the motor being used to generate heat as described earlier? The one thing that never does appear is a bar in the energy consumption meter that some Model S and X owners have talked about. If the motor was using current to generate heat, it was not visible from inside the cab. So as a final note, it is still not completely clear what causes battery warming/preconditioning when charging in cold climates. Regarding the "Limited Charging" warning, this was clearly due to the low temperatures that the car was being charged at.
Lessons learned: The Model 3 is not able to differentiate between a faulty connection and a low temperature. The Model 3 is able to rewarm the battery pack in less then 11 minutes at -6C so that the blue bar and snow flake disappear, but charging rates are severely affected, which was expected. From use, it is very obvious that the car will unlock regen much faster when it is kept plugged in over night or when not in use. Considering that I tried to recreated the scenario described in the owners manual regarding warming a cold battery and was unable to generate a discreet icon like in the Model S and X, Tesla could do a lot more to inform its Model 3 customers what to expect in terms of normal operating behaviour in cold climates. If we are not sure how the car is supposed to operate normally, how can we be certain that it is? The operators manual states that the user can warm a cold battery by activating climate control, it does not specifically state that the motor will draw current while parked to generate heat and warm the battery. It could be that the high draw from the cabin heater, which as shown here is clearly coming directly from the battery and not the wall, is responsible for the heating. It could also be that it is just contributing to heat being generated by the motor.
And lastly, I really love my Model 3. Before purchasing, I had a lot of questions related to whether or not an EV could work for me. After driving my Model 3 across North America and back this past summer, the obvious answer for warm weather driving is a resounding YES! The only question left is whether that remains true for cold weather driving. So far as we head into Christmas, I have not had to deal with a situation that the Model 3 could not handle. Except for the desire to have a little more range then is currently available to allow more coping ability in and EV during extreme weather conditions, temporary limitations in regen ability are easily managed. However, the decrease in charging rate and range could be more problematic for some. Aside from small tweaks in software function and the documentation that should be included, Tesla could probably make small improvements to the Model 3's door handles as it relates to cold climate ownership. While the cold weather update seems to have adequately addressed problems with plugging and unplugging the charge wand, problems with the door handles persist. Obviously this is a hardware issue and will likely require a future update to what ever mechanical part is sticking in the Model 3 door handle. Would I have cancelled my reservation had I known all of this information before actually configuring my car. Not even a chance! The Model 3 is hands down the best car I have ever owned. When it does so many things right, it is hard to criticize such a small blemish.
![10.jpg 10.jpg](https://teslamotorsclub.com/tmc/data/attachments/343/343974-5c7ebfb459782a0cdb34b873da78e695.jpg)
