Considering that it is talking about preparing the "batter", it probably will be sticky.^^^This post should be a sticky!
I type slower than I can think. I forgot to mention the front Stator motors, while preconditioning to the supercharger, will go from the normal temps of 60-65 to 120-130F with the Stator motor warming things up at 2.0-2.5 kW. Note, if you do this at home while stationary, both motors will need 3.5 kW of energy, but, this is more effective than driving. I can get my battery pack to ~ 80F while parked preconditioning for 25-30 minutes because the front Stators can hit 210F and the rear can hit 170F. While driving, the front is only getting to 120-130F and the rear 90-120F.Since the 3 & Y lack a dedicated battery heater like the S & X, the car uses the front Stator motor to help warm the battery. Since the car is primarily RWD until you lose traction, the rear motor is going to produce some heat naturally while you drive. During preconditioning to the supercharger, the front motor pulls typically 2.0-2.5 kWh. In temps below 50F, I find the front motor is generally around 60-65F, the rear motor is around 90-120F.
I posted in another thread 2 months ago that it appears it's almost impossible to get the Model Y to optimal charging temps by using the NAV preconditioning. The highest I've been able to get the coolant before it enters the battery pack is 91F. This was ~ 45 minutes of driving around with a supercharger as the NAV destination. If the coolant never hits 100F, that means the battery pack will never hit 100F.
In colder months, yes, since 7 kW is needed to power the motors, plus the time it takes to get the battery to optimal temps. The last time I did a v3 season in 32F temps, by the time it hit 100F (battery pack), I was at around 35% (started at 9%).Just thinking of the significance of this - does this effectively mean that the Y will have slower charging in the first ~10 minutes or so because of this? I.e., S/X will charge faster whenever navigating to a SC?
It's the motor running inefficiently to generate heat to warm the battery.Speaking of supercharger preconditioning: Do you all experience a high pitched whine when this is happening?
Yeah, I figured. Strange that I never noticed it before on our Model 3 SR+ (maybe it's a front motor thing?).It's the motor running inefficiently to generate heat to warm the battery.
Correct.Yeah, I figured. Strange that I never noticed it before on our Model 3 SR+ (maybe it's a front motor thing?).
I've noticed that sometimes it sounds different from others. Most of the time I don't notice it being all that high of a pitch. Last time the temps were only ~55F and it sounded so shrill that I almost cancelled it to stop the sound.Yeah, I figured. Strange that I never noticed it before on our Model 3 SR+ (maybe it's a front motor thing?).
It depends. If the car is parked and preconditioning, it can use 3.5 kW per motor, so 7.0 kW just to heat up the motors. Another 500-1000 watts to run the vehicle, heat pump, etc.Does it make that much difference in charging rate? When my m3 preconditions it just uses extra energy 3-5 miles of range that needs to be recharged in the battery when I get to charging. It seems like a minute or two??? extra is worth it if I don't need to pay to put it back in energy. Is it just wasteful?
