Ah... first I've heard of an MCU having that for flash. When was your MCU replaced for this previously?no i mean this and i have it ....
Chip on board - Wikipedia
Can you post a picture of your Tegra pcb?no i mean this and i have it ....
Let's hope!Maybe if this gets publicized enough Tesla will offer a refurbishment service that is affordable, and stops (or significantly reduces) the logging that goes on. But I wouldn’t count on it.
Shoot, Elon might even earn himself a reputation for being kind to the environment by eliminating all that e-waste.
I've not used that exact location. I've used the contact us form once logged into my account. 3 times in the past 3 months -- no response. Maybe you'll have better luck though...What might also help is many MCU1-owners complaining about this issue to Tesla, for example using this form on their web site: Contact | Tesla.
Note that you have to choose a topic that doesn't fit, because there are only limited options to choose from (they still need to fix that).
I just did this and asked them politely to be open about this issue to the affected Tesla owners and find an acceptable solution well before the inevitable black screen actually hits them.
Note: I forgot to add that a cheap / free MCU1 --> MCU2 upgrade would also help to ease the pain, but feel free to add that as well
Logging on a Linux system can be directed to tempfs in RAM, and then only retained at log rotation or if needed...I have not read every post in this thread but it appears a large portion of the writing to this Nand flash device are low level Linux operating system logs. If so I can see where they would be helpful in some cases but should not be written to a Nand flash devices routinely on customer cars. For a quick fix maybe redirect the operating system logs to /dev/null and only enable them if that level of logging detail is needed (probably almost never in the field). Another way of reducing wear to the Nand flash would be to cache many log entries and make a one single write to the Nand flash with all the cached entries. Caching would be harder because it would probably entail changing kernel code?
Mine just died in Sept. Is your car still under ESA warranty? I see you have a 2014... Your replacement time is, unfortunately, coming regardless.Hey, does anyone know if using the API with an app like Teslafi increase the logging activity on the MCU? Wondering if it is a good idea to suspend my Teslafi account as a preventative measure on my older S85.
I suspect the primary impact would be if it kept the MCU from sleeping as much.Hey, does anyone know if using the API with an app like Teslafi increase the logging activity on the MCU? Wondering if it is a good idea to suspend my Teslafi account as a preventative measure on my older S85.
