Also of interest... I have a Roadster wall charger in the garage. It's a 90A circuit, has been installed for over six years, and so far zero problems.
Congratulations - you can spend less time doing this now. On a more serious tone you're wearing out the outlet, easily negating any possible savings from the tiny idle electrical draw or the wear on the internal circuitry.Oh I hardly ever take the UMC with me. In my mind, I just thought keeping it plugged into the wall outlet would contribute to the "wear and tear" of the UMC unit itself when not in use, not to mention slow and tiny continuois energy draw from the outlet for no reason.
It's safer to remove the plug from the outlet, so there's not a live pigtail hanging from the wall socket.I leave mine plugged in. But you could disconnect the adapter from the UMC instead, leaving the adapter plugged into the outlet.
1279-W50I looked on Leviton's web site, and don't see a 14-50 that looks like the pic in post 1.
I wonder if that's some POS Chinese counterfeit?
wondering if it would happen if you first turn off the breaker before plugging in (of course this might transfer the need to replace the breaker!!). Most of the 14-50's ive seen are black and so maybe they don't show the discoloration from the arc when the connection is made
Overall recommendation would definitely be to leave the UMC (or new Mobile Connector) plugged in. All EVSEs are designed to use very low power when idle, and plugging and unplugging repeatedly will wear out the socket faster, which can increase resistance/heat, etc. (On the other hand, an occasional unplug and plug cycle may help clean oxidation off the contacts.)
And yes, a permanently wired and permanently mounted EVSE is technically the best: most efficient, marginally safer, potentially higher power (if needed), etc.
Ironically the ~$100 nice Hospital Grade Hubble 14-50 socket cost closes half of the gap between Mobile Connector and Wall Connector pricing.
Nope. There is no load when you're plugging in and therefore no arcing while plugging in.
These are not failing as they are being plugged in, they fail while you put a long heavy load on them, sooner or later.
There is no reason to have a "portable" connection on such a large critical load.
Plugging in regularly does help score the contacts but can weaken the tension over time.
OP has the right plan, get a Wall Connector. Problem solved.
Makes me sick every time I see, "Hey I'm getting a new Tesla and have a 14-50 outlet being installed". Ugh.
I wish Tesla would not include the UMC so more folks would consider the Wall Connector, so much more robust in many ways.
I'm not an electrician, just an EE. But I suspect that this may have been caused by a poor connection at the socket. If the connection isn't tight and the resistance is high, it gets hot. At 40 amps, it only takes .06 ohms of resistance to produce 100 Watts of heat. (W=I*I*R).
If you eliminate the GFCI Breaker that should be on the 14-50 circuit and not required for wall connector it ends up cheaper for the Wall Connector. Oh, don't forget you have to buy the 14-50 adapter now too.
Can’t cite the nec, but it’s commonly stated on the forums that an ev charging circuit is supposed to be dedicated, and have gfi. Whether that applies to a 14-50 outlet that you plug the hpwc into may be up to interpretation, beyond my pay grade. I would sure put in a really good 14-50 if I needed the flexibility or just have the hpwc wired directly.
I have not found a regulation that require GFCI on a 14-50. Link?
GFI is built-in to Tesla Chargers. Doubling up can cause problems in certain situations. Bottom line not needed IF your outlet is properly sized, installed, etc.Personally, I didn’t wait for the code to have to tell me to apply common sense.
But here you go.
2017 NEC requires GFCI 50 amp breaker for 14-50 NEMA outlet intended for EV - Tesla Owners Online
By the way don’t stick a fork in a toaster that’s plugged in, there is nothing in the code that says you should not do that.
The code specifies a dedicated circuit for 14-50, 14-30, etc. There is code regarding GFCI breakers on 120 V circuits in garages, etc. I have looked, but not exhaustively, and have not found a requirement for 240 V outlets to be GFCI. The are a lot of blowhards on these forums who spout "facts" without substantiation.
