Part of being an "EV" is simplicity, which includes lack of oil changes, emissions testing, exhaust part replacement, etc.
Another name we don't need. PHEV works, PHEV40 for the Volt if you want to be range specific. Simple, descriptive, accurate, and avoids all confusion with actual EVs. Enough confusion and damage has been done by calling the Volt an EV.
I personally will not call any car with a gas tank an EV. My choice. I will always refer to it as a hybrid, or if pressured a hybrid EV.
Update 4: Here is what should be the final update, an interview posted at PluginCars with Andrew Farah, the Volt's Chief Engineer explaining the whole process. Put simply, there is a mechanical connection between the ICE and the drivetrain, but it is not being called a "direct" mechanical connection as it only works in concert with torque from the electric motors. There are "situations where we will take mechanical torque from the engine," according to Farah, but there is no arbitrary speed restriction. It's "based on the efficiency map" and is related not to speed, but overall torque in the system.
I want my car to be a ZEV. If it has a tailpipe, then it isn't a ZEV...
I always call them "plug-in hybrids". It was the simplest way to explain it to people at the auto show. They understand immediately, and many were shocked to discover the Volt was a hybrid (there was one opposite my car, so it came up a lot).
But that's no good if you have to keep another one with a tailpipe in the garage.
Not so bad if the backup car only gets used maybe one day a month, and extra parking is available.
Besides, a gas/petrol rental could substitute for those ready to let go of the long distance road trip car.
But, unlike me, you do regular long drives, so the need for the gas mode is much greater for you.
Did you consider getting a shorter range EV (like the LEAF) as your local car and just rent/hire a car when you need to do a long distance business trip?
But I hope you also explained that unlike other plug-in hybrids, you can do most of your driving without using a drop of gas.
By the way, that reminds me, rental car locations would be a good place for L2 charging stations. You drive up in your EV to rent a "gasser" for that occasional long trip.OK, if I have to go somewhere at very short notice I could drive to a rental station and get one ...
Depends whether it's a "leftover" car or a new car, surely?This is what I am saying about having a whole other car - with embodied materials and emissions - sitting around doing nothing for 95% of the time.
EV when technically used in an acronym, refers only to the drivetrain being electric. Therefore you can also technically say a typical hybrid is an EV, but no one ever says that. This is because "EV" without any modifier is typically used as a synonym for "electric car" which refers to a car powered solely by electricity as an input (no gas tank at all).But a Model T is way simpler than a Model S. You can't equate simplicity to EVness. If you look at the terms they all involve moving the car forward.
EV - Electric motive force
HEV - Hybrid motive force, part Electric, part ICE; not compete ICE or EV drive.
PHEV - Hybrid motive force, part Electric, part ICE; not complete ICE or EV drive. You can plug in to save a small amount fuel.
then you have the Volt/Karma generator or board EVs.
EREV - I don't really like this term but is seems appropriate
GEV - Generator Electric Vehicle
PGEV - Plug in Generator Electric Vehicle
It actually goes up to 62mph. 0-30 is about the same (because the gas engine doesn't have to turn on even in hybrid mode), 0-60 is 20 seconds compared to 11 seconds with the ICE on.This got pointed out before but a Plug in Prius is a Hybrid car. It cant go faster than 40, or accelerate at real world rates without its ICE. A Volt/Karma can function as a real car on EV only mode. And these cars can not function without their EV drive at all! A Prius can operate without its EV power train, not fully but it can operate. The Volt* and Karma can't.
The car is a hybrid if it uses two or more onboard energy storage systems to power the car. Since any generator+gas tank used with the Model S will never be a permanent part of the car, it's not a hybrid. If it gets integrated into the car, then it is a hybrid.Then if you power your Tesla Model S with a gasoline generator does that make it a Hybrid? What if that generator was on a trailer? What if you put the generator in the trunk? When does the care become Hybrid?
Typical hybrids also have electricity generation plants carried around with them at all times. That doesn't make they "pure EVs".The Volt/Karma are pure EVs. They just happen to have an electricity generation plant carried around with them at all times. Should we call your Model S a coal/nuclear/solar/wind Hybrid Electric Vehicle?
The Volt's ICE can't move the wheels on it's own. But it does provide mechanical assistance above 70mph in CS mode (just like a Prius ICE does for highway speeds). That makes it a series-parallel plug-in hybrid. If the ICE was completely decoupled, that makes it a series plug-in hybrid (like the Karma).And the ICE in theory can assist the drive wheels directly. But this is not entirely true, and in actuality the ICE can NOT power the car forward at all.
..... I've discovered that I'm "meh" about almost all the cars here - they have ICEs. Not interesting to me now. .
...... Part of being an "EV" is simplicity, which includes lack of oil changes, emissions testing, exhaust part replacement, etc. A hybrid or plug in hybrid, however it is constructed, is at least twice as complex as an EV.
So you don't actually feel the same way at all :wink:EXACTLY how I feel.
GSP
PS. Unless that ICE is just a range extender....![]()
