I have both teslafi and SMT. I see 507km on the screen, the same as when the car was new(after a update about on year ago, initially 499/500km was max range) which is the EPA range. I have seen 508-509km range when i had a NFP of 81.5-81.6kWh and reached 82.0kWh nominal remaining.
For you, 75.5kWh should equal about 475km at a max charge, as each km on the range is 159wh. Do you know the range at full charge when the car was new ?
I do not think you have lost 8%, I guess you had less than 82kWh capacity accordning to the BMS. Most M3P start between 80 and 80,5 I think.
How is your charging habits ? What SOC do you charge to daily ? Is your M3P China built ? There is another english ‘21 M3P with similar NFP as your car, despite low miles. Do you have Full Pack When New = 82.1 kWh?
This is my teslafi data so far:
On 80% charge I usually get an estimate of 382km, and with 100% it varies around 472-476km, where as original it stated 505-506km.
I started using teslamate shortly after having the car (300km after)
When you are asking if I know the range when it was new - I assume you mean the displayed range, and it was 505-506km.
Also I can show this from my teslamate graphs:
Also, can see charging habbits over time (range versus charging levels):
I have a 1 phase 16amps 230v charger at home, the mobile charger from tesla, so I charge frequently, mostly to 80%, obviously some peaks to 90-100%, and usually recharge at 40-50%, yet obviously sometimes below. Had two occurances where I started charging only at 4%, and 9%.
Super charging about 20% at the time, only when had a long trips and had to, even though its free right now in my area, and there is a supercharger really close-by
All of my charges are done towards my departure, so it never hangs too much on high SoC, although I did have some times where I left it at 80% for a day or two. When I went abroad I tried leaving it at around 60% charge (this can be seen by comparing both graphs above, you can see a straight line of mileage)
Re your last questions - I usually charge to 80%, and its US built (vin starts with 5YJ).
In the last screenshot I kept of SMT (I wanted to see the values I would get at 100%, although it didnt finish calibrating), taken at 15300km~, I see:
Nominal full pack: 75.6kwh
Energy buffer: 3.40kwh
SOC: 101%
SOC expected: 100%
Full pack when new: 82.1kwh
Cell imbalance: 6mV
I usually drive gentle since daily car and family car, and usually heavy traffic, but its a performance model and I live in a hilly terrain, so lots of ups and downs...I do flat out when in the mood
My average consumption based on the screen trips (trip B was never reset), is 190kwh.
It can also be seen (by an estimate, since its via tesla api) in teslamate:
Do you think that If I would plug an OBD reader when car was new, I would see to begin with a lower SoH (Nominal full pack) than 82.1?
Doesn't it mean that there is quite a variation between delivered cars? I would expect that all batteries will come with similar capacity, but if there is even 2-3kwh difference, its quite a big one, since it projects to 15-20km of EPA range.
