Candleflame
How long do you need to sit above 85% for the cells to balance, ballpark hours figure
This is for the Model S:
And remember the resistive bleed circuits are pretty delicate in their load. The 4 158 Ohm resistors in parallel are 39.5 Ohms with the cell Voltage about 4 Volts, that means the bleed current is about 0.1 Amp, dissipating about 0.4 Watts. The Amp-hour capacity of these packs is about 85 kWh / 370 Volts or about 230 Amp-hours. That means that it would take 2.3 hours to bleed 0.1% off of a set of paralleled cells. That's a very delicate and gentle balance that only works in a reasonable time, if the cells are almost matched to start with.
The Model 3 has way weaker bleeding circuits to give less vampire drain (i seem to remember 1/10?).
However. it depends how much imbalance there is to start with and noone here ever provides much evidence that their battery is truly out of balance.
The imbalance can be easily read out with SMT and noone here has ever shown that their battery is significantly non balanced, even when spending virtually no time above 85%.
