the old OEM 19 wheels won't fit around refresh oem brakes
Has anyone actually confirmed that? I am skeptical that the new 19" have significantly more interior clearance than the old 19" ones.
Maybe I was just remembering this somewhat speculative post which still needs confirmation re pre refresh 19". Also there were at least 3 versions of pre refresh 19s, maybe some work better than others.We havn't comfirm if the pre-refresh 19" has enough barrel clearance for the refresh Model S's bigger caliper.
However, even if it clears, you will still need to run spacer or otherwise the wheel will sit very tuck in to the fender.
With a 32 offset on both they will only be tucked in by 4.7mm in front and 12.7mm in the back, should be fine. Narrow tires are better for snow as well.In any case, they will look pretty narrow and tucked. They also might deviate the suspension geometry too much. Total speculation though.
Maybe in deep fresh snow but worse in all other cases, mainly compacted snow and the most common, cold dry or cold wet roads.Narrow tires are better for snow as well.
I just mounted Michelin pilot sport all Season 265/35-R21 on the front and 295/35 R21 on the rear of my new 2022 Model S LR with 21Hey guys,
I take delivery of my 2022 MSP next week and I am trying to get a set of winter tires ordered so I can get some use out of the car in the new year. My tire guy is planning on this setup, any cause for concern?
Front setup:
Touren TR75 19x8.5
Pilot Alpin PA4 255/45R19
Rear setup:
Touren TR75 19x9.5
Pilot Alpin PA4 285/40R19
I think you have a great plan hear. With my setup I’ll probably have to get a third set to make it through the spring shoulder season.I just mounted Michelin pilot sport all Season 265/35-R21 on the front and 295/35 R21 on the rear of my new 2022 Model S LR with 21
Arachnids. The fronts are standard factory size and the rear is a 295/35 vs (295/30)on stock. This is the closest size Michelin makes to stock rear in an all season. The rear is 1 inch taller than stock but clears without a problem. This allows me to run one tire year around without having to switch out between the snow tires and performance summer tires each year.
Curious how they compare from a road noise perspective. Heard the 20s are a bit loudI just mounted Michelin pilot sport all Season 265/35-R21 on the front and 295/35 R21 on the rear of my new 2022 Model S LR with 21
No complaints on noise so far. Was 23 degrees this morning and tires were quiet and provided outstanding handling and grip. Very happy with this decision so far. YouTube reviews of this tire in winter conditions showed pretty impressive snow and ice performance also.Curious how they compare from a road noise perspective. Heard the 20s are a bit loud
P Zeros are sold in a few flavors. The way to tell for sure is look for an "M+S" on the tire sidewall. If it has "M+S", then they are considered all-season tires. P Zeros for the winter will also have a pictogram of a 3-peaked mountain with a snowflake inside (3PMSF symbol).I posted this in another thread, I though I would try here too. This may be mentioned above, so my apologies if so:
So, I brought my MS into the SC yesterday to have them swap out my summer's for all-seasons. A couple hours later, I get a call saying that my wheels are already all-seasons, and it says so right on the tires. He insists. I'm like, "what?", and totally embarrassed. I come buy to pick up the car, and no where can I find where it says all-seasons. Now, it is my service advisor seems embarrassed. A technician comes out, and shows us the brand new replacement tires, which are EXACTLY the same as mine. Pirelli PZero's. They had inventory labels on them that said:
1420241-00-A 255/45R19 100Y, 19AS
1420242-00-A 285/40R19 103Y, 19AS
Looking here at TMC, those do seem to be the correct all-season tires. I am heading to the snow in a couple of days, and while it is too late for me to do anything about it now, I could use some reassurance.
