Car Wash Mode takes care of that for you.Is there any change to add the feature "switch to neutral" with a button? I'm always fiddeling with the stick when entering the (belt type) carwash![]()
Mine doesn’t work either. I spent some time yesterday trying to figure it out and it never reengaged.Same here. I tried the new option and it didn’t work for me after changing lanes and when TACC was still active.
Oeps, forgot that one...Car Wash Mode takes care of that for you.
Not for now. CarWash should help with your use-case.Is there any change to add the feature "switch to neutral" with a button? I'm always fiddeling with the stick when entering the (belt type) carwash![]()
If you long press a button for 15 seconds it will unpair from the Commander. The Long press is only 2-3 seconds so we didn't expect that you will hold it that longI have problem with buttons that have long press setup. Suddenly when I long press a configured button, I get en error and the button is lost from dashboard, lose function (both single and long press) and I have to connect the lost button from the beginning...
Yes, it's supported. See all supported models here: S3XY Buttons FunctionsWill they, or do they work with the 2023s?
Thanks
I didn't long press 15 seconds. Maybe 5 seconds and then the buttons unpaired...Not for now. CarWash should help with your use-case.
Yes, we are waiting for the new cable which should be available for Christmas. In the meantime, we saw that some customers had the Model Y from Austin with the normal harness so if you want the buttons now it's best to check if you have the cables with the blue connectors at the back of your CC and if it's there you can order the current bundle without additional cable.Did you guys get Austin 2022/2023 sorted out yet?
If this happens again, please, send the issue to the support team at enhauto.com.I didn't long press 15 seconds. Maybe 5 seconds and then the buttons unpaired...
This is still on the table but it looks like it's more difficult to be implemented with the current Commander who has access to only one of the CAN Buses. We still plan to introduce something which will help in most cases but will probably be a Beta version and not mature because the algorithm will not have the access to all the signals in the car.Hi Ditmar, what about a smart function option which auto re-engage AP after a few seconds when switching lanes? That should be a top feature
My '21 MYP also have barely any room to put the cover back on. I "folded" the connectors as best as I can to take up as little space as possible and pushed hard to get the cover back on. It's worked just fine since the installation, but installing the harness on Model Y apparently is quite a bit more difficult than Model 3 due to the lack of space. I certainly did not enjoy installing the harness, but once installed, I love these buttons.Does it look like Fremont Model Y started to use the Austin style connectors? There isn’t any extra space to put back the cover
Our 2022 MYLR, made in China, is also the same. It was a struggle to get the cover back on compared to our 2019 M3P but it has remained closed since I did the installation a few months ago.Does it look like Fremont Model Y started to use the Austin style connectors? There isn’t any extra space to put back the cover
My '21 MYP also have barely any room to put the cover back on. I "folded" the connectors as best as I can to take up as little space as possible and pushed hard to get the cover back on. It's worked just fine since the installation, but installing the harness on Model Y apparently is quite a bit more difficult than Model 3 due to the lack of space. I certainly did not enjoy installing the harness, but once installed, I love these buttons.The
On my 22 M3P, it was really tight and I had to fold wires and stuff quite a bit. The commander didn't fit and it sits on the floor near a seat. It's not a problem there.My '21 MYP also have barely any room to put the cover back on. I "folded" the connectors as best as I can to take up as little space as possible and pushed hard to get the cover back on. It's worked just fine since the installation, but installing the harness on Model Y apparently is quite a bit more difficult than Model 3 due to the lack of space. I certainly did not enjoy installing the harness, but once installed, I love these buttons.
Do the buttons turn on/off the emergency lights?
