If you go back to every major bounce / rally we've had in 2020 - 2022, you will have a hard time finding anything that began with such a clean impulsive pattern. This is super important as to "start things right", the first spike tells you a lot about what the rest will look like.
In EWT, there are 2 main types: motive and corrective. Motives set the trend while correctives are counter-trend. Obviously in a bear market, we don't want a rally to be corrective as that implies sooner or later, the downtrend will resume and new bottom will be made. There are a lot of corrective patterns but ONLY 1 begins with a 5 wave pattern such as the below example. Therefore, what played out today is hugely bullish for TSLA as it has overcome the first hurdle. Motives ALWAYS begin with a 5 wave sequence. While this still carries the risk of being a zig zag which will play out if, says, TSLA misses Q4 ER expectations, bulls are finally having the upper hand here.
What's next?
I'll repeat: I'm seeing this first leg topping out around 185-190 before pulling back to 175-170. Again, if you don't agree, go back and look at every major rally in the past. The first leg up always retraces deeply before going back up again. I don't care what you're looking at, from 2019 June crash to COVID crash to 2020 split crash to 2021 supply chain crash to 2022 Fed crash, no matter how strong the first spike is, it always retraces at least 50%. Expect it and plan around it.
Why do we have to pull back? We only rallied 17 points from the low and already a double bearish divergence can be observed on the 30m timeframe. Momentum is running out and we're due for a pull back, especially after all 5 waves have mostly played out.
Caveat: this is a small degree sequence. Looks to me like it's wave 1 of 1 of 5, 2 degrees removed from the typical big rally we often see. At this level, things can get a bit erratic. Says tomorrow Buffett says he's buying TSLA - we're going much higher. That's why I'm not planning my CC's around sequences of this degree. I'm only looking at the one above it, which gives me 195 as a safe strike. Max I see for big wave 1 of 5 is 225 before retracing to 195 at the minimum. Will I still hold on to my 200 CCs exp next week if Buffett says he's buying TSLA? Heck no. But most everything else can be managed just fine.
The beauty of a 5 wave sequence for starter is this: even if this is just the first leg of a zig zag, the retracement cannot extend beyond the previous low. It means once we've done pulling back, 200 will come before new lows, if any. I know this is of little comfort to many of us here, but this is a small victory regardless. We take it one day at a time. Wishing everyone a happy Thanksgiving!
