Are you sure? If you have a 85, you'll get the option to buy a 350V 85 kWh with part number 1014116-00-A, if you have a 90 kWh you'll be offered 1014116-00-B90kWh is what you are buying, not an 85.
That is my understanding
Remanufactured might be 85 since not new. Very curious to see if the warranty on the used batteries has changed.... Maybe after backlash they changed it - but I'm sorta doubtful as the document is dated 2020 and people have posted since then otherwise.I'm skeptical.
Definitely get that in writing![]()
Okay, I believe youSo have you confirmed that it is not SW limited to 85 by Tesla?
Personally, I think spending 20k+ to fix what's effectively the ICE equivalent of a major mechanical problem on a Tesla is probably a pretty terrible idea. Easily half the value of the car or more. $5k or so, sure. $20k? Not so much.
Financially and practically that makes lots of sense, but been human beings some of us have this thing called 'sentimental value' attached to our cars even though the reality is they are innate objects and should be treated as such.
I use to laugh at a colleague who spent $$$$ (and still does) on his 1980s BMW 3 series including putting in a whole new engine and transmission through a BMW main dealer. Its not a M3, or a collectable BMW, its just a normal 3 series but it was his first brand new car and he treats like a ospring.
Despite me mocking him years ago, I suspect am heading down the same path with our Model X, as the saying goes 'those who laugh last laugh the loudest'.
A new bicycle is $2000
A rusty 87 tercel is $800
So Hoovies story got a sequel via the Rich Rebuilds channel. Apparently the Electrified garage changed the bricks that were of balance with closely matched bricks.
@wk057
you mentioned that this is not the preferred way of working/best solution. I am curious what the ownership experience of Hoovie will be with this repair done to the tesla.
Most of all I’m curious how to interpret the data they showed on screen (when is a module not balancing?)As am i. I'd like to hear from him in about 4 months.
A module is not balancing when any of the readings differ significantly from the average. The differences are highlighted by the software to make them easier to spot. A perfectly balanced battery would have all numbers the same.Most of all I’m curious how to interpret the data they showed on screen (when is a module not balancing?)
It can't disable a whole block either. So if things get too far out of balance it disables the whole pack.As of now, the battery packs have no way to disable bad cells individually (like bad clusters on a hard drive). So the car does what it can and disables the whole block. This means 1 bad cell in a block disables all the good ones, leading to a big loss of range.
Of course they would be, just as all our batteries would be. Batteries degrade around 5% the first year and 1% each year afterward, so an "85" would be an "80" after the first year alone, much less "in a year or two". Anyone thinking they have anything near original battery capacity after a year is dreaming.they'd basically be below original 85 specs in a year or two anyway, if not sooner.
Did you just mansplain battery degradation to Jason Hughes?Of course they would be, just as all our batteries would be. Batteries degrade around 5% the first year and 1% each year afterward, so an "85" would be an "80" after the first year alone, much less "in a year or two". Anyone thinking they have anything near original battery capacity after a year is dreaming.
Did you just mansplain battery degradation to Jason Hughes?![]()
By this I mean, within a year or two a 90 and an 85 built at the same time (or otherwise tracked and aligned to make such a comparison) would have BOTH degraded, obviously, but the 90 would have degraded MORE, to the point where it has equal capacity to the same age 85. From that point on the 90 would have less capacity than the 85 for all time.
Because of the chemistry of the cells in the 90kWh packs. (Especially the early ones.)Due to battery design of the 90kwh battery?
