This is one of the more prominent flaws in Model 3. Has been around long enough without being fixed that one may suspect Tesla don’t see/realize this is a significant issue - especially in Europe.Any idea how to set cruise control at current speed (and not maximal currently allowed - which is probably derived from central map database - very often wrong number - at least in europe)?
I suggest you provide this proposal as feedback to Tesla on their home page under "Support" and then "Contact us". There is a form to fill in. If enough people make this suggestion they may realize there is an unmet need.Any idea how to set cruise control at current speed (and not maximal currently allowed - which is probably derived from central map database - very often wrong number - at least in europe)?
I think in autopilot setting there is a setting for cruise relative to speed limit. Turn off that feature and see if that fixes your issue
I reported this bug to tesla maybe a year ago - at first they didn't acknowledge that it happened, as it doesn't on model S and X's, then I finally got them to acknowledge that it did, after many emails, and they said it was a bug that would be fixed soon. They still haven't. i give up dealing with these morons about this. Anyone else want to try?
You actually got them to reply? Which email / who did you communicate with. I’d be happy to take up where you left off. All they have to do is to implement a choice for the users - should not be too hard a decision if they acknowledge the need.I reported this bug to tesla maybe a year ago - at first they didn't acknowledge that it happened, as it doesn't on model S and X's, then I finally got them to acknowledge that it did, after many emails, and they said it was a bug that would be fixed soon. They still haven't. i give up dealing with these morons about this. Anyone else want to try?
I would also not characterize it as a bug - more like a sub-optimal design for certain situations. But something that has a simple solution.
I have no problem setting the cruise control to my current speed. It always works perfectly.
So, you are saying that if you are in a 70 mile per hour zone and you want to set it for 50, you just go 50 and set it somehow "Without having to scroll?"
Wish I knew this secret as I have a posted speed of 30 mph (50 km/h) and the map speed (WRONG) says 60 mph (100 km/h)!
Very frequently have to scroll. What am I missing?
That's a situation that would be very rare for me, but yes, it would just work (as long as Tesla's map data say 70mph); I have set a relative speed offset of -20 mph. In that case, the Speed Assist-determined speed and my current speed would both be 50mph. So that is what will be set for TACC.
It's extremely rare that I would want to use TACC to travel at a speed more than 20mph below the map-determined speed limit. You'd never use cruise control in inclement conditions, so it's not an issue for snow or rain, where the "basic rule" speed limit (the actual speed limit) may well be way below the posted limit.
I have the same problem as @ibbd above so one time it is correct and my wife doesn't hear the over speed "boing" and the other gets the "boing" frequently. Setting the speed offset would probably put me over speed for all my travel, so couldn't use the speed warning which I quite like, cause as we all know, the car will go crazy fast so easily
Would be really nice if I could just push the "Park" button while at speed and it would set the cruise to that speed. Wouldn't take much programming IMHO.
They acknowledged it as a bug at the time. I stopped caring soon afterwards, and don't know if that paragraph was in the manual at the time or if they added it to cover their asses. It's easy enough to work around.
Here's a copy of the manual from last January - I can't find anything like what's in post 4. Perhaps I'm looking in the wrong place. But as I stated before, I don't really care any more. Whatever.AFAIK the manual has always, clearly, stated that the current behavior is intentional and meant to work that way. It's not a bug, it's a feature.
Owners Manual you posted said:Traffic-Aware Cruise Control makes it easy to cruise at the speed limit. You can cruise at the
speed limit that is currently being determined by Speed Assist (see Speed Assist on page
79). To do so, move the gear lever fully down once then release. When you release, your
cruising speed is set to the speed that is determined by Speed Assist, taking into
consideration any offset you have specified. If you are already driving faster than the speed
limit when you pull the lever, the set speed does not adjust to the speed limit—it adjusts
to your current driving speed.
