Probably time for .40 to drop globally ... *crosses fingers*
Yep I have the same complaint. In my case I do it when I have passengers as the airflow to the rear is so poor. I used to set airflow to be only vents and then close two or three of them to get more airflow to the back of the car while leaving all the rest of the functions on auto mode.Has anybody else noticed the regression in auto climate control in V9? In V8 you could have it in a partially auto mode -- for example you could leave the vent selection (feet/head/both) on auto but override the fan speed. But now auto seems to be all-or-nothing; if you change any setting it drops the whole climate control system to manual.
I rather dislike this because my standard practice in the fall/spring (cool outside but not frigid) was to set the temperature quite low (60-64F) but disable the A/C compressor, in order to essentially disable the heater (due to having temperature low) without actually cooling the car to that level. But now when I try that trick it switches the whole system over to manual so I have to constantly tweak all the settings to be comfortable.
my release notes are blank along with the web browser most of the timeJust now updated from .39.6 to .40, the release note looks the same.
While I agree with that first statement of avoiding over the shoulder head movement if at close range to a vehicle in front, I'll just stick to the process that has worked for me for 50 years without incident. And that is to continue looking over my shoulder.
I can't count the number of times it has prevented me from hitting someone even with looking in the mirrors.
On iPhone, if you don’t see the Tesla icon in Send to... options, scroll to the end. You should see three dots. Tap them, More Options menu should open. It will show additional Apps that could receive data. Tesla icon should be there. Select it. Then close that menu.What app are you using to send directions from? I cannot see how to do this from within Waze.
That really sounds like misconfigured mirrors.
Just two observations for V9 39.7. I haven't been tracking the changes for a while so this may not be new or if new, may have already been posted.
1. Lane change work on surface street. It didn't work before
2. I cannot force a lane change into the HOV lane if it is has a solid white or double yellow lines (as per the law)
Thoughts?
I think you are right. I never thought of that, now my car starts rolling, and I have to slam on the brakes. Before that force use to enable hold mode, not any more.Yes, and something subtle I noticed is I have to press the brake pedal with much more force at at stop light (or similar stop) if I want to put the car into "hold" mode. Before this version, it didn't take much brake pressure to do it. For me, I prefer it to be the way is was previously.
My web browser is hit or miss since upgrading to 39.7. One day it works just fine, then another day it doesnt. Reboot doesnt fix it. No idea what the rhyme or reason is.
seems like just installing tomato on an existing $30 router is easier?
Yes definitely Easier, but for my Needs I needed Wider Coverage. My House is very Wide and a $30 Router can't hit all the Corners.
So the Ubiquiti System allows me to have multiple Access Points. Otherwise my Tesla wouldn't have got a Signal.
Plus I need Strong Signal for having Alexa "Play Music Everywhere"
Just press the brake pedal hard to engage vehicle hold. I use it frequently in hills, or when stopped at red light on flat ground, so the car will stand still even when in Drive and Creep is on. Just hit the accelerator to get going again.Does a double press engage hold mode? I'm trying to parse the manual (for a 3) "After coming to a complete stop, simply press the brake pedal again (until the touchscreen displays the Vehicle Hold indicator light) to enable Vehicle Hold."
2nd this. I just got 2 UniFi AP-AC-LR in my house and the management system as shown in the screenshot (omitted in my post) is just out of this world.
Kind of a side rail but how do you like the unifi setup? I've had coworkers rave about them, and I *really* want something not-cloud-based/not-Google, but I'm reluctant to take on managing an enterprise network device at home anymore... too many bad flashbacks to my ops days
