After seeing the solar modeling in the Loop app using my half hourly meter reading I am totally convinced about having a battery as even at this time of year it nearly doubles the self use from the small PV array they assume.
Looking at live usage data, my washing machine goes from nearly 1kw when it is spinning to very little every few minutes while rinsing, so without a battery it would import most of the power from the grid even if the PV had enough output for the total half hour usage. Likewise with cooking at lunch time.
It easy to get higher payments for sending power to the grid if a battery is used so power is sent mostly between 5pm and 7pm, likewise electricity cost for import is highest between 5pm and 7pm. So I would size a battery so in winter using a overnight charge we did not need to import before 9pm on all but the lowerest PV days. Interesting a heatpump only seems to work for us if we have a large battery to run the heatpump on cheap rate electricity.
Its disappointing how little automatic integration with Octopus Agile is fully supported by inverter vendors.
This logic would also support getting even a small battery. So if finances don’t allow a big one that you think would take you through your entire night - an ‘averaging’ battery as a solar buffer of even 2.5kwh could be practical to up your self-consumption during the day. Get a modular system and you can then expand later when finances allow
