We had PV panels fitted in November 2011 and so enjoy the original high FIT. But without the FIT I'm less convinced they are of any real value. Today we have generated all of 968w/hr. We do have a 3kw battery pack, but again its value is marginal.
Solar batteries certainly help but there isn’t a genuine cost justification, it’s just nice to have in that sense.We had PV panels fitted in November 2011 and so enjoy the original high FIT. But without the FIT I'm less convinced they are of any real value. Today we have generated all of 968w/hr. We do have a 3kw battery pack, but again its value is marginal.
I’ve been quandering over the same issue. I contacted MAC (my second contact) both contacts used Google earth? to view my property and subsequently provide a proposal.Not changed then.. the one I went with, despite claims of being 'backed by barclays' and therefore completely safe, went bust 6 months after installing mine (so I have no warranty... yay).
That said.. not sure if he hangs around these parts but on the tesla facebook group they seem quite fond of Mac Cummings. Evergreen MAC
Not at all @VanillaAir_UK most domestic installations are likely not to exceed 16 panels. When I bought, that’s what they wanted to supply. 16 of today’s average panels will probably peak at 4.8kWh. I have several roofs and peak at almost 11KWh.Quite frankly, buy solar panels and maybe even a battery, but only because you like the idea of using some of your own electricity. Don't go buying them because you think that you are being environmentally friendly, will be getting any worthwhile financial savings or will be able to run your car on significant proportion of home generated energy.
Also watch out for @Dilly He has an extraordinary amount of PV compared with what most mere mortals will have so his experiences will not necessarily translate to those that others will experience. I hope he doesn't mind me saying that.
If you are tempted, look at PVGIS, bash in the numbers for your location and an achievable size array (often these are constrained by roof space and/or DNO limits) and look at the estimated figures. Then bear in mind that charging a car at 10A (so less than a third of the speed of a 7kW charge point) will require 2.6kW of excess solar generation or battery inverter capacity then extrapolate the numbers from there.
And you're in the dark orange part of the map. Goodness knows what we'd getAs a warning, for all my panels, today being as dull as dishwater, they produced just 810Wh
I hope to improve winter a bit. I’m pollarding 6 of 12 80ft trees at the back of my garden they only 70ft from the house!And you're in the dark orange part of the map. Goodness knows what we'd get
This almost exactly mirrors my situation and setup. I can only see energy prices heading one way. The RoI on installs is coming down all the time, if that's an important consideration for you.To the OP, I’d say getting solar PV is definitely worth it, provided you can fit enough panels on your roof. But a storage battery is now an essential part of the installation due to the end of FIT and anticipated continued electricity price rises.
I had my solar PV installation in March 2020
This included 14 panels producing 4.2kw max output. Also 7.2 kWh of battery storage. Including the inverter this instal cost £8500 from EEC Solar.
This enables me to run my 4 bed house completely free of grid usage for about 6 months of the year, with the remaining 6 months becoming more dependent on battery storage of £.05 per kWh off peak.
On the sunniest days I’m making about 30 kWh per day, but on the darkest days I’m making only 1 KWh per day.
I’m on track to break even in about 10 years. But with off peak charging of the battery storage this comes down to about 7 years.
A couple of observations having had the system for 18 months:
1) I wouldn’t bother getting Solar PV without a battery. The batteries are expensive. But the ability to store cheap off peak electricity is a key part of the cost benefit. I’d say 7kwh if battery capacity is about right four our family of four.
3) I think my solar array of 4.2 peak output is a bit small for my family. I would say a 5kw PV system is the minimum that a family of four would need. Stretch to 7kw if you can afford it.
2) Don’t bother with Tesla battery storage. They really don’t offer the benefit to justify the significantly higher cost. But I have no requirement for off-grid usage having never had a power outage. This may be important for some.
3) I have a Zappi to charge from solar. This is useful for about 6 months a year when my storage battery gets charged by solar by about 2.00 PM which leaves excess solar production to charge the Tesla until sunset. Otherwise I just charge off peak at night. I think the extra cost of the Zappi is just about worth it.
4) This may make some of you cringe but I added the £8500 cost of my solar panels on my mortgage at the point of renewal. This added £35 per month to my mortgage on 2.5% interest. I judged this to be a capital investment that would outlive my home ownership. So even though my panels will pay for themselves in 10 years, they are part of a 25 yr mortgage.
I hope all that helps.
Llama
It's not a zero sum game is it though? You present your argument as if it's an either/or question.There is one positive aspect though, in that if you are able to afford both then you can personally contribute to a cleaner grid that bit sooner, but still likely at lower cost effectiveness than grid-scale providers can achieve in the near term.
I wanted an EV, I could have waited longer, instead I bought a Tesla Model S, which was a trade-off between time and pricing to achieve an objective sooner. So ultimately it's down to individual viewpoint, hence just my various thoughts for the OP on 'is it worth it?'It's not a zero sum game is it though? You present your argument as if it's an either/or question.
I didn’t get PV and a Powerwall 2 to save money, anymore than I bought a Tesla to save money; I did it for the experience and the project. Very much enjoying it so far.
