Yes it's likely to be correct assuming they are 380 to 400w panels giving you a 3.8 to 4kW array.We have just ordered 10 panels (max due to Velux windows ) se facing roof and 2 x 9.5kwh give energy batteries for £14k fitted by eon. They have only quoted for 1 inverter. Is this right? not interested in export as we use 23 kWh daily at home.
Thanks
Thanks
How it works for me is like this...
Our Tesla Powerwalls are still on Time Based Control at the moment. So the AI uses Go Tariff during the night to top up the Powerwalls from the Grid.
If we then have a poor Solar Day, our home usage is then easily covered by the cheap Grid storage.
However, if we have an unexpected good Solar Day... the excess gets put into the cars.
I reckon I'm going to go down that route too.
(I have high background usage due to computer servers)
Had 16 South-facing panels and 2x PowerWall. Charged PowerWalls overnight on E7 ... Solar never exceeded household use - or not by much, and some PowerWall discharge had occurred before sun came up so there was a bit of room to store any excess PV during the day.
Added a further 32 ESE panels. My back of envelop maths was that this would not be enough ... Only had them 10 days and not had a blue-sky day yet but looks like it is peaking at 3.5kW (does that sound right?)
... they were commissioned the day before I went on holiday, and I had not read the Zappi manual to figure out how to consume any excess into the EV. So whilst away I watched it merrily exporting to the grid for most of the day ...
I tried to change Cheap Rate to be only an hour to minimise the level that the PowerWall charged to (not knowing of a different way to limit that). Turns out then when sunny the 48 panels will charge the 2x PowerWall from 20% reserve to full in 2 hours! so any overnight charge can't be used-up before the sun is recharging the battery ...
Although I think there is something wrong (or I am misunderstanding??) but the APP often shows the house using 0kW - i.e. whatever the PV is generating is shown as going into battery, or export to grid. The graph for HOUSE shows 0kW for several hours at a time (probably at the same time that it shows EXPORT happening). This is definitely not possible, the servers definitely didn't stop ... and I never saw 0kW for the house before the new panels were added.
So then I changed the setting to SELF POWERED. Its been like that for a week (dunno if that is enough for AI?) and it hasn't charged at all overnight. We've had 2 or 3 back-to-back overcast days, and it has only charged to top up back to 20% Reserve overnight (i.e. typically "nothing"). On sunny days 2x PowerWall has been fully charged in 2 hours ... and then the rest exported.
So clearly my back-of-envelope was wrong (or something is amiss with CONFIG). I'm not sure I can reliably stuff the excess into EV (some days yes, but not every day if we haven't been anywhere for a few days)
I'm happy to do some programming to have a go with API to try to get better control. If I can reasonably predict sunshine-hours from a forecast (I'll assume that, until I find I can't, and then compromise on whatever I can actually attempt) then I will charge PowerWall to a percentage that will, approximately, get PowerWall charged to 100% during the day and then run that down after sunset / overnight.
Which app are you reading? Tesla?
maybe there is a CT clamp in the wrong place
a CT Clamp sounds 'missing' or not in the right place.
Your house should never show '0kW' unless everything is turned off
What are you designing for? Trying to have enough spring/summer solar to cover your usage and putting it into the battery? Trying to oversize to have enough solar over winter?
You need 'Time Based Control' for the Ai to manage your charging intelligence.
I don’t know if it still is the case but the AI used to only store a couple of days.Yes. Is there anything else available? (I've not looked, but I use TesalFi for driving ... an equivalent API gadget that saved me having to write, and debug!, one for PowerWall would be good.)
Its intermittent though, does that still sound like CT Clamp error? Tesla APP will report house as 0kW for a period (an hour or two maybe) and then a level that seems reasonable. Happy to get the installer to sort it out, but any thoughts would be appreciated.
I was thinking of having enough for shoulder months, and that any excess in Summer could be dumped into car. But I reckon my capacity-needed maths might have been pessimistic (or the dodgy APP output isn't matching reality, and once that is fixed things will even out ... but the PowerWalls go from 20% to full in 2 hours (even if the APP says the house is using 0% it isn't, so I presume that PowerWall Charging is from "spare juice").
Looks like I'm definitely going to have to plan for significant dump-to-car on sunny days. Or take up Aluminium smelting!
Ah, OK, thanks. I did use that initially, maybe not for enough days for AI to learn to compensate? it didn't moderate from just filling the PowerWall to 100% overnight
I'll drop the Reserve from 20% to 10% ... which was where I had it before. Most of our powercuts are a couple of seconds, and if I get a scheduled powercut I can deliberately increase the reserve to 100%
When your second set of panels were installed, was the Zappi solar CT clamped round the the new solar live feed (in addition to the existing) in your consumer unit?
Run the calcs off pvwatt as described back around page 20-30 of the thread and see what you think. I'm Edinburgh with a 14 panel SW facing array proposed, and 8 NE facing. Peak generation is actually around 4kw, but will happen less than 30 hours a year. So I'm happy with a smaller inverter if I can persuade them.I have a quote for a 5.6kwp array (14x400w panels) 3.68kw inverter, zappi and a 10kwh battery. Installation is in Scotland. Installer highly recommends the 3.68 inverter rather than upping to a larger inverter. It will clip to the battery so I am told but can’t help thinking installer can’t be bothered with the DNO paperwork. Excess over 3.68kw may only be for a few mid summer months. Does anyone see any issues with the 3.68kw inverter?
Today was a good day while I was out, we imported 20kWh at 5p overnight, fully charged our single Powerwall and our solar diverter completely topped up our hot water tank. If only our 2nd Powerwall was in, we could have avoided giving the grid 3kW of power worth 15p.
Only a 383.5 year pay backIf only our 2nd Powerwall was in, we could have avoided giving the grid 3kW of power worth 15p.
... and every minute filled with smugness...Only a 383.5 year pay back![]()
Two swindlers arrive at the capital city of an emperor who spends lavishly on clothing at the expense of state matters. Posing as weavers, they offer to supply him with magnificent clothes that are invisible to those who are stupid or incompetent. The emperor hires them, and they set up looms and go to work. A succession of officials, and then the emperor himself, visit them to check their progress. Each sees that the looms are empty but pretends otherwise to avoid being thought a fool. Finally, the weavers report that the emperor's suit is finished. They mime dressing him and he sets off in a procession before the whole city. The townsfolk uncomfortably go along with the pretense, not wanting to appear inept or stupid, until a child blurts out that the emperor is wearing nothing at all. The people then realize that everyone has been fooled. Although startled, the emperor continues the procession, walking more proudly than ever.
