My fit for the winter quarter was approx £50+a small amount for export from a 3.6KW south west facing array. I suspect you have been misinformed or do not understand the historical fit prices.No, I know what FIT is. FIT for a typical winter quarter is about £5, which is as near as dammit nonexistant.
The local DNO use a diversity factor working on the principle not every shower, kettle, or appliance will be on at the same time to size the local distribution system unfortunately this is not the case with solar which will all be on peak production at the same time on all local installs and possibly constant max export for a number of hours which can lead the risk of overloading the local transformers/cabling. A similar thing happens when BEV's become the dominant method of transport and the local DNO will either refuse permission for chargers or through government law take control of all EV chargers. The DNO charger control will happen sooner than people think.The last few posts make me wonder how the domestic green dream will actually happen...
I also don't understand why, if a house can draw 80A at 240v = 19kw it can't export at up to that level.... clearly I'm missing something.
We have a single phase none looped supply, I think: power comes to the house from a cable that goes back to a box on an electricity pole, the cable on the poles goes to a transformer on a pole about 200m away that drops the voltage to 240v.
No, but make sure you get 3 quotes. I've had a ridiculously crazy £4,800 quote for a 4-panel 1.5kW system on a bungalow!Any recommendations for installers (PV and battery) in southeast / Sussex?
Agreed, here are our cash receivables by month for a 3.6kW inverter. The first col is the total.My fit for the winter quarter was approx £50+a small amount for export from a 3.6KW south west facing array. I suspect you have been misinformed or do not understand the historical fit prices.
Generation tariff 56.03p per KWh-export tariff 3.95p-per KWh- assumed export 50% of production- index linked.You must have got FIT when it was at a very high value.. Mostly I struggle to break £300 a year.
True, but even on Octopus GO rate at 15.59p during the day, I'm avoiding £500 a year in electricity bills, and when the day rate doubles, my avoidance will be £1,000 a year. Now, I'd say panels are worth it if you live in the south and don't have too much shading; we have a little shading.You must have got FIT when it was at a very high value.. Mostly I struggle to break £300 a year.
Even in the north if the rate doubles to 30p you will save at least £500 a year off your bill+ any export on a 3.6KW system. System faces SW and generates 1800-2000KWh a year North East coast.True, but even on Octopus GO rate at 15.59p during the day, I'm avoiding £500 a year in electricity bills, and when the day rate doubles, my avoidance will be £1,000 a year. Now, I'd say panels are worth it if you live in the south and don't have too much shading; we have a little shading.
We have that deal... Index linked until 2036 and tax free.Generation tariff 56.03p per KWh-export tariff 3.95p-per KWh- assumed export 50% of production- index linked.
Thank you @Avendit & others.Your 4.5kw system will be peak, unshaded, south facing mid day output. 4.5kw is ~16A, so that's your max on the Y axis.
Throw a nice bell curve over that on the X axis and you have your ideal June day curve, with your 6A cutoff. So maybe putting current in between 9am and 3pm? Maybe 8 and 4? Not sure.
But that's June... Now a Z axis for over the year and that max mid day will drop right off. @RedMod3 above awesomely had some stats, showing about 1/5th power output for Jan to June. 1/5th of of your max power is only going to be 3A, at mid day, and you still have the X axis for the time of day to contend with. So by that bad math you won't really get a charge in the winter as you aren't getting over the 6A minimum (which is correct for the M3 I'm pretty sure).
That's really bad back of an envelope math - in particular monthly output != current supplied - on a really sunny day in or near winter you may crawl over the 6a to do some trickle charging, but its probably not going to win over a regular commute.
Also, at lower charge rates a larger % of your power goes to just running the car systems while it's charging.
Still helps in the summer when you likely do more mileage anyway, but it's not going to be year round free charging .
It's the annoying thing with solar (which I'll hopefully get anyway), it's not really enough for a car, at least not year round, and production is 100% opposite (on a daily and yearly basis) of my heat pump reqs.
But it can conver a lot of everything else so still worth it given the way process are going. Unless my spread sheet is even worse than the above math I think pay back could be as low as 4 years just now! We have a big base load due to some IT stuff and I figure I can move a fair bit of other load to during the day of into an over night rate eventually.
I don't think the government boffins understand what happens to compound interest over an extended period.We have that deal... Index linked until 2036 and tax free.
I'm waiting for "them" to offer a "buy out", with rising inflation it will be £1.00 a kwh before long.
I don't get how you can have a return in 6 year for £20k, how do you get £3333 return every year?I have 9.96 kW of panels plus a powerwall 2. In the full year of 2021 we generated 6.2MWh of solar mainly in the summer months. I am on the TEP in order to benefit from export of surplus energy at the same rate as I paid for importing as FIT no longer exists. With the increasing bills ie so far in my case from 8p per kWh to 11.11p per kWh this year to possibly 20-30 p per kWh later this year I will save more and more. If I could get a second powerwall I would probably change to Octopus GO as I would need to export less.
The full installation cost me £20k and this will be returned in about 6 years.
"them" - that's all of those with electricity bills with the green levy on them - 2/3 of that is your FiT payment.We have that deal... Index linked until 2036 and tax free.
