mdunc
And another on a dessicant dehumidifierIve got one of mine on a large compressor dehumidifier. Interesting to see how it's energy consumption varies View attachment 882743
I assumed all my servers here were the power hogs ... but that was the first thing I monitored, and it isn't them. I'm at a loss to know what is causing the heavy "background consumption" now.
American fridge freezer is quite a power hog
It depends on the average U values of the six sides of the box; it is impossible to comment on sizing otherwise.I have air-air heat pump units in two bedrooms, which they heat in no time, and plan to install three more in the other rooms in which we mainly live (replacing the outside unit with a larger one) so we burn less heating oil.
The installer’s calculation of the heat output in kW required for the new indoor units seems much higher than I had expected based on experience so far. What’s the experience of air-air heating in the group? Would a 3.5kW unit suffice for kitchen/dining area 30m2? My installer says 5kW, but on that basis the capacity of the outdoor unit is exceeded. Thanks in advance.
I've been through this, some things to look at and notI assumed all my servers here were the power hogs ... but that was the first thing I monitored, and it isn't them. I'm at a loss to know what is causing the heavy "background consumption" now. I reckon I'll have to throw breakers until the power drops (I can see that on PowerWall APP ... probably SmartMeter too), but that is likely to turn off something that will be a hassle - electric time clock that will then need resetting ...
swapping the server PSU to a ultra efficient and silent one
Media stuff.
phone chargers
smart plugs use 1w btw - so some of the sonos would have been diminishing returns to automate
we live within solar+battery more of the year which I like.
Biggest culprit tho that I haven't worked out what to do with yet is the heated airer
24KWh a day? Oh boy that a lot to find.I'm 1kW (continuous) short
Thanks for that. Of the things that I am aware of is always on I've only accounted for "not very much" of my background kW usage, in particular all the things I had, wrongly!, assumed would be the power-hogs. I'm 1kW (continuous) short ... which is, of course, a lot.
I've been trying to get our IT guys to do that for all servers without much success ... can you point me in the direction of what you got pls?
Would a storage heater be possible - charge-up overnight to heat during the day?
You mentioned teenagers, are they running a crypto rig at your cost?
I was able to fit this
Great info,. I need to get smart plugs. And find the power hungry device's.Installer should be modeling the house fairly accurately - talk to them to check their assumptions match your knowledge of the building.
Biggest culprit tho that I haven't worked out what to do with yet is the heated airer. Suggestions welcome :/. It unfortunately sits at 200w most of the winter TBH.
- Fridge for us is about 1kw a day (accept or upgrade), but I haven't measured the standalone freezer or wine fridge yet.
- Servers (and switches and router and PoE wifi points) are down to 2kw/day (90w cont) by swapping the server PSU to a ultra efficient and silent one
- Media stuff. Each sonos unit is about 7w idle. 24/7 x 7 units in our case. I now turn off the less used ones and leave one wired in one as a root that doesn't get powered down.
- Equally some old but good stereo and surround stuff was idling at up to 30w when in 'standby' so they now have a smart switch that _really_ powers them all down.
- We don't talk about how much power the projector uses when in use,
- Projector idles at <1w so all happy.
- My PC uses a fancy external water cooling system in which the pump used 20w, again 24/7, so I got one of the e-on smart trigger plugs so that only comes on when the PC is on (PC doesn't see much use compared to the work laptop)
- PC's phone chargers, monitors etc in standby are not worth fighting over.
- Dishwasher and washer/dryer were measured and pushed to overnight and on average slightly more eco programmes.
- We have some z-wave smart lights which let me measure those - you don't really need to measure as you can do the sums quite easily really. But with a kitchen with 5 main spots and 5 worktop spot lights, even with LED lighting that adds up to potentially 50w which are on much of the day. For the main lights I added a motion sensor so if no one is in the kitchen they dim down to using 5w between those 5 bulbs rather than 25 total. High WAF BTW, this automation seems to really work.
- I have a bunch of garden equipment and e-bike chargers in the garage which I've put on a smart plug, so if something needs charged it turns itself right off once charging is done.
- Given our HW comes from the heatpump, I am seriously considering waste water heat recovery for the main shower. Need to do some sums as I suspect they don't really do much, vs the theoretical capabilities and SAP points they are sold on to landlords.
Just had a set of 4 plugs and slowly worked around the whole house finding all this out. Biggest and most painful surprise was the stereo equipment and doing the sums on the Sonos. Also, those smart plugs use 1w btw - so some of the sonos would have been diminishing returns to automate. I just used them on units that are mostly unused for extended periods.
All this gets be down to ~340w overnight from about 500 which I'm pretty happy at. Every 24/7 source of 10w eliminated saves £30. Not much, but sorting out my sonos is effectively an extra meal out a year. The server PSU is another one. And it all means that we live within solar+battery more of the year which I like.
A few questions if I may.Just over 9 months from ordering the solar and storage project is nearly complete. Just over 10kwp split equally east/west with 19kwh of storage. Also a new gen 2 Zappi and Eddi solar diverter (to follow when available). The inverter will also be switched out for the newer more powerful version when they finally reach the UK early next year.
The EPS gives full house back-up and switches automatically in less than 3 seconds. Not seamless but easily good enough as we have UPS on critical gear.
It's been a tortuous route but a very nice installation and a bargain at £16.5k compared to current prices. Good to finally get it over the line.
Looking very tidy, I bet your exhausted - I know I am! Are you batteries earthed to the inverter? Just to the side of the gen2 plug on the battery and underside right of the inverter?Just over 9 months from ordering the solar and storage project is nearly complete. Just over 10kwp split equally east/west with 19kwh of storage. Also a new gen 2 Zappi and Eddi solar diverter (to follow when available). The inverter will also be switched out for the newer more powerful version when they finally reach the UK early next year.
I believe it's a Gen 1 currently installed as the availability of Gen 2 is poor.You say it's a temporary inverter, which are you going to get? I'm quoted for the 5KW Gen 2 Hybrid.
Yes that's correct, same installer as myselfI believe it's a Gen 1 currently installed as the availability of Gen 2 is poor.
Completely agree. Shortest day of the year and still getting half a kilowatt off the north-east panels at 10am on an overcast day.know some people start out thinking that lack of South aspect is a disadvantage, but they have only 50% of the roof to use as the North is useless, and I now think that East/West is far better)
