Gasket fitment and window adhesive are variable issues but the channels created by the A pillar and the chrome trim is IMO a design cause of wind noise. The opening to the A pillar is visible in this clip of the Model Y from Sandy Munro
I wonder if that might not be a good place to shoot in some expanding foam and call it a day?
Could be good right up to the point that you see the rust coming through your panel from the inside.
How is moisture going to get in there?
Can you prove moisture won’t get in there? Water is pretty good at getting into places. If it does, you’ll have made a water trap that breeds rust.
You’re just going to have to try it out and wait to see if it rusts out after a couple of years. Let us know!
I don't need to "prove" anything. Look at the picture. It's effectively a tube with an opening at the end that faces oncoming air currents. If you seal that end, I'd be interested to know how you get water inside. And I believe I will try it.
shrug...
Awesome! I’ll just leave this here:
Any water running down the inside of the A-pillar will collect there if it cannot drain adequately.I wonder if that might not be a good place to shoot in some expanding foam and call it a day?
Isn't adding sugru basically the same as adding the foam?
Awesome. I'll keep that handy in case I ever decide to pour water in my trunk.
yawn...
Nope. Sugru for filling the seam doesn’t seal off the channel from draining water, like that other guy is about to do.
By that measure, any metal surface inside the car is going to rust out from under you. lol
Nope. You are wrong.
It's just the areas where someone was foolish enough to create a water trap like blocking off the A pillar channel.
