I also obstructed the spaces at the base of the front uprights on both sides of the windshield.
I used a drop from the seal kit and in this case, one of the center pilar.
The seal should be put on, keeping outside the U it makes on one of the 2 sides . After removing the red strip to glue the joint, the game consists in gradually stuffing the 2 sides of the U, over the entire length of the slot. I used a thin and rigid plastic masking knife. The joint must be pinched mm by mm.
At the end the joint is crushed with a force, which it really does not risk to move. The result is perfect, we do not even see that it has been added.
View attachment 540112 View attachment 540114 View attachment 540115 View attachment 540116 View attachment 540117
