Haven't checked on v4.3, though.
That was my experience with 4.2 as well, the adapter unlocks for a few seconds. I would expect it to remain locked to the car.
The other question is: Is it better to be able to pull it out and risk no charge or some stolen electrons, or is it better to lock them and then incur damage when the perp tries to pry off the connector?
This doesn't seem terribly patentable to me, but perhaps I'm wrong.
Again, I dont have an MS yet, so I cant say for certain. I just recall reading that the adapter does lock. But if you stop the charging (by removing the J1772 nozzle or stopping charge) that there is a 10 second or so period where the lock releases, allowing the adapter to be disconnected from the car. Is this not the case?
This conflicts with the experience of two others related in posts above.The charge port only unlocks if the car is unlocked. So if someone else disconnects, it stays locked in.
I'm 4.2 and decided to see what my car did. Unfortunately, my test was not conclusive.This conflicts with the experience of two others related in posts above.
Is there a way we can confirm this 100% (noting firmware versions since it can/may change)?
I'm pretty sure the adapter stays locked into the port until the doors are unlocked with the key fob or mobile app but someone will have to check.
Near my home is a medical facility with several ChargePoint stations, and being Sunday, the parking areas were empty. I began a charge using the RFID card, and then walked about 25 meters and laid the key fob on the ground. I returned to the car and without stopping the charge using the RFID card, tried to remove the J1772 nozzle and adapter as a unit - could not.
Removed the nozzle from the adapter. Charge stopped*. Tried to remove the adapter - could not.
Reinserted the J1772 into the adapter and easily removed the combined unit.
I have found that the adapter stays attached to the car as long as the doors are locked. It sounds like you discovered a bug though by reconnecting the nozzle. Clearly Tesla's intent is that you can't remove the adapter when the car is locked. Hopefully they will fix this ASAP.
When the J1772 nozzle release button is pressed, charging stops - no current flow, no zap.Am I going to pull the plug while delivering 30 amps? I don't think so. Pilot contact *should* disconnect before big contacts but not going to attempt this. Contactors opening might be slower than my pulling plug resulting in a big zap. If this is where the exploit might occur then so be it.
I need to verify this by trying again, but using the J1772 adapter at work, I was surprised to find that the whole assembly (J1772 with Tesla adapter attached) came out of the car (car was locked) when I squeezed the J1772's handle and pulled. I was expecting just the J1772 to detach. I'm not connected today because the charger is in use with one of our fleet Volts but will try again to be sure.
Nope. I was wrong. The adapter stays firmly attached to the car when I removed the J1772. I even had the fob in my pocket (with auto present turned off) and had to unlock the car to get the adapter out. Not sure what happened the first time, but I may have unlocked the car first without realizing it.
I looked at my car while using the Blink charging station at work, and it looked to me like there was not going to be any room for your ring adaptor lock thingy. It has to be at least a tiny bit bigger than the plug's latch, and I didn't see any spare room there. But of course eyeballs are no substitute for measurement...
