Mark-R
I finally picked up enough courage to fit my OneStopNumberPlates.co.uk stick-on plate yesterday. A few observations:
I had one of the TESLA.COM holders. I think these are particularly ugly thanks to the four tabs across the top and at the sides. It looks like a really cheap, last-minute addition.
Fortunately, it is easy to remove - just pull the TESLA.COM strip at one end and it pops off then the metal number plate slides out at the bottom. A Philips screwdriver and a 8mm socket are then needed to remove the two plastic mounts. This leaves two holes. To my surprise these were not central i.e. the original number plate was about 10mm to the left of centre I decided to fill the holes with a two-part plastic bumper repair putty which I then sanded smooth. If I re-fit the original holder at some point I will drill new holes and put it in the middle!
I then needed to establish where to stick the plate so as not to interfere with the sensors (mainly the radar). From an aesthetic perspective I wanted to mount the plate towards the middle rather than hugging the bottom of the front ‘bumper’. This thread was useful as a 150mm high US plate mounted 3/4inch (19mm) above the bottom lip does not interfere, so as long as I kept below 169mm from the bottom lip I reckoned I should be OK. I went with 160mm in the end. Attaching the stick-on plate was easier than I thought (in part thanks to Roy’s excellent instructions).
I had the opportunity to test both cruise control and Autopilot on a duel carriage way on a shopping trip this morning and both work without any problems and there were no error messages. So UK stick-on plates can be safely fixed so that the top of the plate is 160mm from the bottom lip, and probably a bit higher if you are prepared to push it.
