this happened to me last night car is in the shop now after the tow.Following this event when I attempted to install 2021.4.18 the update failed. SC said they were unable to remotely format the onboard SD card, which I assume is the navigation database storage and we would need to come in for an appt to have the SD card replaced. Our SC is about an 3 hr drive one way so I kept pressing to see if there was anything else they could do from their end. Finally today they said they tried to remotely format again and were unsuccessful but still send a new update to the X and to try again. I rebooted by changing tire sizes and made sure the sentry drive was turned off and the drive removed. Amazingly the install was a success.
Hope you can get your vehicle working and please let me know what they find with yours.
This happened to me and thank goodness you told me about changing the wheel size I finally got my car to come home but it’s still behaving on and there’s an update but it’s doing now. What was the outcome when you took it to the shop I have to go out of town tomorrow and depending on my car to take me but now I’m extremely concernedThis happened to me
I was using talk to text I apologize the car is still driving odd and when I got home at doing a software updateThis happened to me and thank goodness you told me about changing the wheel size I finally got my car to come home but it’s still behaving on and there’s an update but it’s doing now. What was the outcome when you took it to the shop I have to go out of town tomorrow and depending on my car to take me but now I’m extremely concerned
Thank you thank you thank you for the wheel size trick!!! You literally just saved my 4th of July weekend. Had the car off problem also on my X and nothing else workedHad the same thing happen a couple weeks ago. Had to have our 2020 X towed in and by the time it arrived at the service center all was working. They claimed it was caused by the sentry drive I was using. Try removing the drive and rebooting. I also have found the change tire size reboot to be more effective.
If all else fails you can open the frunk and disconnect the red terminal wire behind the panel of the upper frunk trim.
Changing the tire type worked for meI had same issue with my 2020 X today. Stuck in “Car Off” despite all electrical running.. few soft and hard reset did nothing. Tesla could not remotely troubleshoot and ended up having to tow the car… then noticed “ transportation mode” would not work either! Basically car could not go to Neutral to load to truck! What a painful day! Hopefully by tomorrow I learn about the solution. I wish I had seen this thread sooner and had tried the wheel size trick ….
