Technically that might be true since we can't "know" anything unless Tesla comes clean on all aspects. But there's enough circumstantial evidence that you'd almost have to be delusional not to suspect the capping was part of the fire investigation:
So you have to ask yourself, what is more likely? All of the above are coincidences, or... Tesla did what they said they were going to do: push an update out of "an abundance of caution" to mitigate fire risk while they continue to look for the root cause? Just the Tesla announcements alone are too much of a coincidence: (a) they announce the China fire was the result of a single bad battery module, (b) they announce that they are pushing a "cautionary" firmware that changes charge and thermal management... and it turns out that you get capped if you have a problem in a single module.
- Tesla investigates Model S fires and claims the problem was in a single battery module
- Tesla announces an update to change charge and thermal management while they investigate the root cause
- As soon as 1 day after the update announcement, some owners start to see the capping
- The capping update was later discovered to cap if a problem was found in a single battery module (the fire condition)
Based on the information we have at this point, I'd say that if your car got capped: (a) the software detected a module in your car that has an issue, and (b) you got capped in an effort to reduce fire risk in your car.
Mike
Thanks for your rational and objective post.
You would think, wouldn't you?
Sadly, I doubt your precise and logical articulation would convince the delusional posters, or those who pretend to come across as, based on their ulterior motivations.
We have been dealing with several of Tesla apologists since the beginning of this thread. Some came, tried to poison the discourse, gave up, and left. Few are still here and persist.
