jaitch
Maybe Tesla are delaying the inevitable expensive battery replacements until they have made a fortune from the Model 3, Roadster, truck et al.
At least they made the MS capable of quickly swapping batteries. Looks to me like they are going to be replacing a lot of them under warranty. If this happens to the M3 they will be screwed. Have you seen an M3 battery removal video yet? I wonder how easy it is to replace an MX battery.
I wonder what you disagreed with me @Zhelko Dimic here?
Even without considering other types of precedents, there are at least two very clear cases like this kWh/performance limiting in Tesla’s past.
Limiting number of full performance launches on Tesla Performance models via firmware:
Pack Performance and Launch Mode Limits
Limiting DC charging speed based on DC charging counters via firmware:
If you fast charge, Tesla will permanently throttle charging
Both were done silently and only came to light through customer research such as this thread.
What makes you think this is not normal for Tesla?
@electronblue You can add P85D horsepower to that list, Tesla lied and is still not delivering what they sold. I think they did the same thing to P90D owners.
Both mine and my friend's are DWhat is your battery part number? Is it the same as your friend's?
The number is on a sticker on the front right side of the battery.
Reminds me of Apple, except the device is 100 times more expensive.Isn’t this completely ”on character” for Tesla the company, though?
This is not the first time something like this has happened. Not even the second time.
People generally have woken up to this fact at their own pace but I think a lot of folks would agree by now this is simply the way Tesla operates and has done for years now.
This is the Tesla normal — and it is not new.
FYI, "D" is no longer a sufficient answer - once they rev the part number, the number and letter suffix revert to "00-A"Both mine and my friend's are D
As a recent P90DL owner (not appreciating what difference versions of battery make to performance) I feed that Teslia misled me somewhat - so yes.
I think Tesla has discovered lithium plating in some battery packs. The reduction in max voltage is an attempt to prevent further lithium plating (which could ultimately result in failure or fire).
From what I can tell, the difference here is a potential safety issue (thermal event - fire - due to short circuits from lithium plating). Launch mode limitations, in my opinion, were corporate gaffs attempting to mitigate driveline wear (half shafts, etc.). The P85D was borderline false advertising -- I say borderline because they did a straight kW to HP conversion at the pack level, similar to advertising engine crank horsepower instead of wheel horsepower. I'm not also fully-informed on the details of the P85D horsepower issue, so I might be misunderstanding something.
Actually it was way worse than that. They advertised 691 hp but even if you do straight hp at the battery before inverter and mechanical losses to the get the motor shaft, the P85D Insane still only made 555 hp 100% charged at max battery ready and far less than that on a not too cold or not too warm battery at 80%.
The 691 hp case was sort of reverse of this range loss though.
In that case Tesla shipped a car with less than advertised performance and made vague promises of future firmware updates making it all right. (Never happened of course.)
The case at hand is the reverse of that: removal of shipped features via firmware.
Although I agree both cases are related to the same ethics issues at Tesla.
Li-plating happens mostly at the anode this true, but it reduces the amount of cycle-able Li which is affecting cathode stability at higher SOCs. From the comparison table in my former post you may estimate the hidden reserve of NCM over NCA!According to the various battery longevity studies I've been reading the past couple of days, lithium plating is most likely in all-graphite anode batteries (like the 85 kWh and other earlier packs). I've seen nothing that specifically references NCA chemistry compared to others.
