faughtz
Model S P85DL
These continuous assertions from Tesla that there is no actual range decrease and that it is a change in the range calculation is just outright infuriating.
And an outright lie, as we can see the module voltages.
I don't even know why Tesla has forums on its site. It just serves to make them look bad when they pull censorship stunts like this.
90,000 cars * 5% * $20,000 battery replacements == $90 million. Frankly in the noise. Even if it was 25% of the cars, it would be affordable.
The problem at Tesla is a communications problem, period, end of story. They're creating ill-will by failing to communicate.
Another aspect of recent update - AC pump runs for extended period after charging ceases. At this stage my Sept 2015 P85D VIN 5YJSB7H4XFF089069 is not showing range reduction, but........since the recent software upgrade the AC pump continues to run after the charger is disconnected. This did absolutely not happen before a few weeks ago.
I was first alerted when heard a buzzing in the front end hours after charging ended and car sitting in garage and not activated. Car was checked by Tesla and found no errors, and subsequently agreed with Tesla that it was AC pump running. Yesterday I charged car on a Supercharger to about 96% ending at 6kW charging rate preparing for a long drive, drove home 3 km and left car overnight before departure. AC pump kept running after car shut down, and still running an hour later. When I got up in morning 10 km of range (=2 kWh) gone from battery so AC pump kept running for hours and used up that energy.
I have raised this with Tesla (Australia), so far no response.
Please also note that our recent firmware updates included an update to the range estimation algorithm to better reflect range usage.
Why are Tesla employees so quick to make stuff up when they have no clue what is happening?
A - They are totally uninformed about the issue which customers are asking for help about, and keep copy/pasting the Tesla's generic talking points
or
B - They know what's taking place but are told by the management to deflect by giving generic non-answers
Either way, it's pathetic.
It would be interesting to see corporate staff performance goals, and the associated metrics, by role/title. What’s rewarded by tesla as success?
I emailed support questioning my 24 mile drop in range.
Their reply:
Hello,
Thank you for contacting Tesla! Please allow me to apologize for the delay in our response to this email.
There are many factors involved in the actual range of your Tesla, and why you may feel that your actual range or charge capacity does not match up to the high voltage pack capacity. The battery pack is sized to provide range. Our range is carefully calculated and measured according to rigorously reviewed standards, as well as an on-board algorithm that constantly learns your driving habits and adjusts the predicted range accordingly. In contrast, a vehicle’s battery pack energy capacity varies with the rate of discharge and cell temperature.
If there is a concern with the range of the vehicle, we will be happy to work through this to address any issues being experienced
This seemed to be my trigger mechanism, which then resulted in about 8kWh capacity loss, with a 40kW performance hit. Good luck.
Sure. Max power dropped from 116-118kW to 70ish dropping fast while charging. Power@50% dropped from 75kW to less than 50kW. Chademo would reach max of 48kW@67% before all this, but now the car limits the charge so much I only get like 30-32kW at that SOC. Normally chademo power would ramp up towards that soc point, but is now impaired from approx. 57%.For clarity, could you specify what Supercharging / ChaDemo charging rates you were getting before and what rates you're getting now? (If you're being reduced from 120 kw to 105 kw, it means something different than if you're being reduced from 50 kW to 35kW)
Also looks like they are closing threads on the Tesla site on this as well![]()
My worry is that this is a larger issue than it appears to be, and maybe it is something recall-worthy... and Tesla is being shady about it trying to sweep the issue under the rug with software limitations that they won't explain. No proof of that, but it wouldn't surprise me in the slightest.
Just imagine how much it'd cost Tesla to have to recall and replace even a small percentage of 85 packs. There's something like ~90,000 cars out there with 85 packs, and another ~40,000 or so with 85-type cells. If say 5% of those needed to be replaced, that's like ~$125,000,000 in parts, not counting labor or anything. Would be a bad hit for sure.
If Tesla would willingly replace affected batteries without any hassle, it would create goodwill and boost sales. OTOH, if Tesla refuses to do so, it will cost sales.90,000 cars * 5% * $20,000 battery replacements == $90 million. Frankly in the noise. Even if it was 25% of the cars, it would be affordable.
Based on Hanlon's razor - WikipediaA - They are totally uninformed about the issue which customers are asking for help, and keep copy/pasting the Tesla's generic talking points
or
